Intermittent internet and frequent disconnects
Rossmor48
I have getting very intermittent internet since Tuesday with a lot of disconnects, loss of synch. It seems to be one of the SNR problems which feature a lot on these forums but according to the service status checker there are no issues in my area.
can anyone tell what the messages from the Hub 5 mean
30-06-2023 16:42:19noticeCM-STATUS message sent. Event Type Code: 5; Chan ID: 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 26 27 28 29 30 32 33 35 38 40; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3
30-06-2023 16:42:17noticeCM-STATUS message sent. Event Type Code: 4; Chan ID: 10 11 12 13 15 16 17 18 19 20 21 22 23 24 26 28 29 30 32 33 35 36 37 40; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-06-2023 16:41:58warningMDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-06-2023 16:29:49noticeCM-STATUS message sent. Event Type Code: 4; Chan ID: 10 11 12 13 15 16 17 18 19 20 21 22 23 24 26 28 29 30 32 33 35 36 37 40; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-06-2023 16:29:46noticeCM-STATUS message sent. Event Type Code: 5; Chan ID: 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 26 27 28 29 30 32 33 35 38 40; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3
30-06-2023 16:29:26warningMDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-06-2023 16:26:39noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-06-2023 16:23:06noticeCM-STATUS message sent. Event Type Code: 5; Chan ID: 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 26 27 28 29 30 32 33 35 38 40; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3
30-06-2023 16:23:05noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-06-2023 16:22:31warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-06-2023 16:22:31criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-06-2023 16:22:21noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-06-2023 16:20:30criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-06-2023 16:20:03noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-06-2023 16:12:49criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-06-2023 16:12:35noticeCM-STATUS message sent. Event Type Code: 4; Chan ID: 10 11 12 13 15 16 17 18 19 20 21 22 23 24 26 28 29 30 32 33 35 36 37 40; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
6 REPLIES 6
Rossmor48
Some further info
04960000051.55120QAM 641
14310000051.85120QAM 642
236600000505120QAM 643
330100000505120QAM 644
423600000515120QAM 645
0ATDMA00180
1ATDMA00170
2ATDMA00160
3ATDMA00160
4ATDMA00180
13310000000.541QAM 25625
22110000000.141QAM 25610
32190000000.241QAM 25611
42270000000.541QAM 25612
52350000000.239QAM 25613
62430000000.141QAM 25614
72510000000.141QAM 25615
82590000000.140QAM 25616
92670000000.341QAM 25617
102750000000.441QAM 25618
112830000000.241QAM 25619
122910000000.341QAM 25620
132990000000.141QAM 25621
143070000000.341QAM 25622
15315000000041QAM 25623
16323000000041QAM 25624
173390000000.341QAM 25626
183470000000.241QAM 25627
193550000000.441QAM 25628
203630000000.241QAM 25629
213710000000.741QAM 25630
223790000000.441QAM 25631
233870000000.241QAM 25632
243950000000.241QAM 25633
254030000000.341QAM 25634
264110000000.541QAM 25635
274190000000.341QAM 25636
284270000000.241QAM 25637
294350000000.441QAM 25638
304430000000.741QAM 25639
314510000000.641QAM 25640
1Locked4132100312932
2Locked41334225378
3Locked41962472230164
4Locked401091968119846
5Locked41101725070652
6Locked41919618193140
7Locked41724433181520
8Locked371013305108048
9Locked4186263965996
10Locked4167255790183
11Locked4153709481543
12Locked416615912019
13Locked4112464834516
14Locked4152932899105
15Locked4128370068320
16Locked411449886017
17Locked412589707624
18Locked4125558428876
19Locked4119479927911
20Locked41600103330
21Locked41303611353
22Locked4110295825312
23Locked4119687528248
24Locked4110614136029
25Locked418940669547
26Locked417622074481
27Locked417081370599
28Locked414678021478
29Locked418415523872
30Locked4111149620095
31Locked419621520059
Hi @Rossmor48
You also need to post the top section from the Downstream page showing the power levels etc
Plus you need to post the information from the Upstream tab (power levels and time outs)
Also go to /thinkbroadband.com/broadband/monitoring/quality  and set up a BQM (broadband quality monitor)
On Think Broadband go to your  BQM and under the options you will see
Today | Previous Days | Edit | Delete | Share
Click on the Share option and on the screen that opens click on Share
On the next screen click on Share Live Graph
Copy the text in the Direct Link box (beware there may be more text than you can see so make sure yuo highlight it all)
On here when creating your post click the Link icon (2 links chain to the left of the camera icon)
 In the URL box paste the link you copied and then click OK.
13310000004.341QAM 25625
21390000004.840QAM 2561
3147000000541
Dave
The do's and don'ts.
Hey Rossmor48,
Welcome back to the community and thanks for taking the time to post.
I’m sorry to hear of the issues that you’re having with your broadband connection, I have looked into this on our system and cannot see anything that would be causing the issues that you're having and your latest graph seems to show that your connection is okay now. How has it been since you last posted?
Kind Regards,
Steven_L
Rossmor48
Hi Steven,
The broadband connection is back to normal now. I am not sure what caused all the issues last week with. Tuesday and Friday being particularly bad but connection been normal for a day and half now.
Hagain @Rossmor48
Thanks  for updating the thread. Fingers crossed the connection stays that way.
Any further issues though just do the same again and holler.
Dave
