  • 11
Message 1 of 8
Intermittent huge latency and packet loss on WiFi
Hiya, we're having problems with high latency and occasional packet loss that only seems to be a problem on WiFi.
Powerline connection: 100Mbit download, zero packet loss on packetloss.com, absolutely fine.
WiFi connection, holding my phone 30cm from the router. On 2.4G only, Great wifi signal, I have my SSID and Virgin Media on channel 1 with almost identical signal strength (coming from my router), and my neighbours on channels 6 and 11. I have 5G switched off because it struggles upstairs. Sometimes works fine on wifi, sometimes huge latency and packet loss, between 1 – 100% late packets and occasionally up to 30% on packetloss.com.
Thinkbroadband monitor, some dropouts today where I've reset the router
Today has been much worse but it's been an issue for a month or so, possibly longer
  • 11
Message 2 of 8
Re: Intermittent huge latency and packet loss on WiFi
186750000
Locked
Ranged Upstream Channel (Hz)
46200000
Locked
Provisioning State
Online
1186750000-0.238256 qam7
2194750000-0.538256 qam8
3202750000-0.738256 qam9
4210750000-0.738256 qam10
5218750000-0.738256 qam11
6226750000-0.738256 qam12
7234750000-0.738256 qam13
8242750000-138256 qam14
9250750000-138256 qam15
10258750000-1.438256 qam16
11266750000-1.238256 qam17
12274750000-1.538256 qam18
13282750000-1.538256 qam19
14290750000-1.538256 qam20
15298750000-1.538256 qam21
16306750000-1.938256 qam22
17314750000-238256 qam23
18322750000-2.238256 qam24
19402750000-3.538256 qam25
20410750000-3.537256 qam26
21418750000-3.538256 qam27
22426750000-3.538256 qam28
23434750000-3.538256 qam29
24442750000-3.738256 qam30
1Locked38.650
2Locked38.650
3Locked38.650
4Locked38.6110
5Locked38.650
6Locked38.6170
7Locked38.6190
8Locked38.940
9Locked38.650
10Locked38.650
11Locked38.660
12Locked38.650
13Locked38.940
14Locked38.660
15Locked38.940
16Locked38.960
17Locked38.650
18Locked38.6150
19Locked38.630
20Locked37.630
21Locked38.660
22Locked38.610
23Locked38.660
24Locked38.6120
  • 11
Message 3 of 8
1462000004.4512064 qam1
2326000004.3512064 qam3
3394000004.325512064 qam2
4537000004.425512064 qam4
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsl10016u-b.cm
SFID469938
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID469937
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
01/01/1970 00:01:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 14:48:5Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 14:48:5criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 14:44:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 14:44:46criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 14:38:36criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 14:38:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 14:38:34criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 14:38:33Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 14:38:31criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 14:38:25Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 13:00:37noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 12:20:51criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 12:20:49Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 12:20:49criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 12:20:15noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 10:35:11noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 3.16K
  • 132
  • 186
Message 4 of 8
Thank you for your post Jwtaylor876.
Are you getting any of these issues through any wired devices?
When you say you've rebooted the Hub, was this through a pin hole reset found on the back?
Let us know, Emily.
  • 20.96K
  • 1.13K
  • 2.7K
Message 5 of 8
A better router or mesh system will solve this
  • 11
Message 6 of 8
Hiya, I've only occasionally had brief problems on a wired connection, it's mostly wifi issues. Having said that it's been much better the last couple of days, only 1% late packets maybe on wifi.I've only rebooted by pulling the power cable out the back- might there be any benefit in using the pinhole to reset?
  • 11
Message 7 of 8
Just had another complete wifi outage this morning. Sat next to the box with -35dB wifi signal on my phone but not connecting. Wired connection fine. Had to pull the power cable to reset to make it work again. I suspect a dodgy box rather than interference. Next time it happens I am going to hook up my old router in wifi mode connected via cable to see if that works during the same time period as the V6 wifi is goosed. This is not a suitable long-term solution though
  • 20.96K
  • 1.13K
  • 2.7K
Message 8 of 8
No but my solution above is
