forumarchive,nothingtosee,
Mcass
Message 1 of 5
Intermittent hub 2 WiFi
Constantly rebooting, won’t reach upstairs. Similar to others on here. The family switch to mobile data constantly whilst we pay for M100 broadband.
https://www.speedtest.net/my-result/i/4437988533
Any help gratefully received.
  • 20.43K
  • 2.18K
  • 3.61K
Message 2 of 5
Re: Intermittent hub 2 WiFi
Try a pinhole reset of the Hub first and see if that settles it.
Is it just over wifi connections or do you have the same problems on an ethernet cable connected device at the same time.
Mcass
Message 3 of 5
Thanks for replying. It’s WiFi only.
Do factory resets work? I’ve read on here it makes no difference.
  • 20.43K
  • 2.18K
  • 3.61K
Message 4 of 5
But have you tested it on ethernet cable ? That will give a clue as to whether your issue is a VM network connection one - or just a wifi only one.
You say "constantly rebooting" a reset may cure that - or may not.
Mcass
Message 5 of 5
Thanks. Tried the reset. I’ll see how that helps with zooms etc across the week.
cheers
