Intermittent dropouts London N16
Switched to virgin early this year. I'm on the 500Mbps package.  Since then I've been getting increasingly intermittent dropouts area reference 15.  When it happens I notice I can ping the router ok but can't ping externally.  Then when it returns I might be able to ping externally but can see some timeouts.  Would it be possible to see how this looks?  I'm getting a 'No Ranging Response received - T3 time out' when I check the log
Thanks!
Cable Modem Status
Item
Status
Comments
235000000
Locked
Ranged Upstream Channel (Hz)
53700854
Locked
Provisioning State
Online
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
235000000
0.2
38
256 qam
13
2
243000000
0.2
38
256 qam
14
3
251000000
0
38
256 qam
15
4
259000000
0
38
256 qam
16
5
267000000
0
38
256 qam
17
6
275000000
-0.2
38
256 qam
18
7
283000000
0
38
256 qam
19
8
291000000
0.2
40
256 qam
20
9
299000000
0.7
38
256 qam
21
10
307000000
0.9
38
256 qam
22
11
315000000
0.7
38
256 qam
23
12
323000000
0.7
38
256 qam
24
13
347000000
0.5
40
256 qam
25
14
355000000
0.5
38
256 qam
26
15
363000000
0.7
40
256 qam
27
16
371000000
0.9
40
256 qam
28
17
379000000
1
38
256 qam
29
18
387000000
1
40
256 qam
30
19
395000000
1
38
256 qam
31
20
403000000
0.7
38
256 qam
32
21
411000000
0.7
38
256 qam
33
22
419000000
0.5
40
256 qam
34
23
427000000
0.7
40
256 qam
35
24
435000000
0.5
40
256 qam
36
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.9
8
0
2
Locked
38.9
8
0
3
Locked
38.9
8
0
4
Locked
38.9
8
0
5
Locked
38.9
16
0
6
Locked
38.9
7
0
7
Locked
38.9
9
0
8
Locked
40.3
8
0
9
Locked
38.9
5
0
10
Locked
38.9
7
0
11
Locked
38.9
9
0
12
Locked
38.9
8
0
13
Locked
40.3
8
0
14
Locked
38.9
6
0
15
Locked
40.3
6
0
16
Locked
40.3
12
0
17
Locked
38.9
5
0
18
Locked
40.3
9
0
19
Locked
38.9
8
0
20
Locked
38.9
8
0
21
Locked
38.9
8
0
22
Locked
40.3
7
0
23
Locked
40.3
6
0
24
Locked
40.3
0
0
Re: Intermittent dropouts London N16
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
53700854
5.196
5120
16 qam
2
2
60300531
5.196
5120
16 qam
1
3
39399663
5.196
5120
16 qam
4
4
46199633
5.196
5120
16 qam
3
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsxxxl500u+voc-b.cm
SFID
1402920
Max Traffic Rate
575000000
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
1402919
Max Traffic Rate
38520000
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffort
16/06/2020 08:54:49
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2020 23:34:3
critical
15/06/2020 23:18:17
notice
15/06/2020 22:49:20
critical
15/06/2020 22:24:2
notice
15/06/2020 22:22:15
critical
15/06/2020 22:21:52
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2020 01:32:35
critical
15/06/2020 01:32:31
critical
Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2020 01:32:31
critical
Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2020 01:32:3
critical
15/06/2020 01:32:2
critical
15/06/2020 01:32:2
critical
15/06/2020 01:29:16
critical
15/06/2020 01:28:58
critical
15/06/2020 01:28:58
critical
15/06/2020 01:20:12
critical
15/06/2020 01:20:3
critical
15/06/2020 01:20:3
critical
15/06/2020 01:17:31
critical
Just to update got through to support pretty quickly this morning and the lady spotted something on her end.  An engineer is scheduled for tomorrow which seems positive.
Interested if anyone sees anything from the logs.
Thanks!
