davidharris_
  • 15
Intermittent disconnections
For about a week or two I have been seeing frequent but intermittent drops in internet connection - online applications I am using just freeze for a few seconds up to a minute or so.
What's confusing me is that in the past this has been reflected in my BQM, but not this time:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/1e6806c9f19d1700b4ed9709134f623e3577502c-06-02-2023
Power levels I think are okay too:
12670000005.438256 qam17
21390000004.537256 qam1
31470000004.837256 qam2
41550000004.937256 qam3
51630000004.837256 qam4
61710000004.937256 qam5
71790000004.837256 qam6
8187000000537256 qam7
9195000000538256 qam8
10203000000538256 qam9
11211000000538256 qam10
12219000000538256 qam11
132270000004.938256 qam12
142350000004.538256 qam13
152430000004.338256 qam14
162510000004.538256 qam15
17259000000538256 qam16
182750000005.538256 qam18
192830000005.838256 qam19
20291000000638256 qam20
212990000006.138256 qam21
22307000000640256 qam22
233150000005.638256 qam23
243230000004.538256 qam24
1Locked38.69361
2Locked37.6241145
3Locked37.6268145
4Locked37.6173158
5Locked37.6201130
6Locked37.6172149
7Locked37.3186111
8Locked37.619199
9Locked38.6142124
10Locked38.917388
11Locked38.6138107
12Locked38.914262
13Locked38.613175
14Locked38.612365
15Locked38.910449
16Locked38.610849
17Locked38.69846
18Locked38.69242
19Locked38.69334
20Locked38.99236
21Locked38.69224
22Locked40.37332
23Locked38.9871
24Locked38.65721
Any suggestions greatly appreciated!
Many Thanks
David
davidharris_
  • 15
Re: Intermittent disconnections
There are some messages in the log. But there is only 1 from this morning, at just after 8am, whereas I have had several disconnecitons since then:
06/02/2023 08:03:12criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2023 17:36:7Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2023 16:35:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2023 16:35:34criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2023 16:35:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2023 16:35:14criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2023 16:34:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2023 16:34:34criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/02/2023 16:33:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/02/2023 16:33:54criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/02/2023 16:33:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/02/2023 16:33:34criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/02/2023 16:32:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/02/2023 16:32:54criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/02/2023 16:32:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/02/2023 16:32:14criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/02/2023 16:31:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/02/2023 16:31:54criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/02/2023 16:31:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/02/2023 16:31:14criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Kath_F
  • 34.71K
  • 1.33K
  • 2.81K
Hi davidharris_,
Thanks for taking the time to post about your issues in the Community.
We're sorry to hear you're having an issue with your broadband connection.
Taking a look at things this end, we can see there is a short term stability issue showing. I've checked the hub power and signal levels and these need adjusting. We won't be able to fix this remotely so I would like to arrange for an engineer to come to take a look at this for you.
I just need to confirm the address to ensure we are booking the visit on the correct account. I have sent you a private message regarding this. Just click on the little plum envelope at the top right-hand side of the page to access your inbox.
Kath_F
Kath_F
  • 34.71K
  • 1.33K
  • 2.81K
Hi davidharris_,
Thanks for coming back to us via private message to confirm your information.
I have booked you in for the next available appointment. To view this please sign in to My Virgin Media here: My VM. Once you log in scroll down to Orders & appointments then click on View your orders. Please note it can take up to 24 hours to show but you should also receive a text message with the details. You can also view this in the My VM app. If you have any issues with accessing your account or unable to see your visit, please do let us know and we’ll pop you a message to pass data protection and confirm the appointment details.
Just to confirm, there will be no charge for this visit unless:
➡ The technician diagnoses the faults as not being caused by our network/equipment
➡ The technician discovers that the fault or problem relates to your equipment
➡ The technician discovers that the fault or problem relates to any system that we are not responsible for
➡ The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
Please ensure there is someone over the age of 18 present at the time of the visit. If you need to change or cancel your appointment you can do this online or via the MyVM app by 4pm the day before the appointment. If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment.
We will continue to monitor your services and if we can see that the fault has cleared and the visit is no longer required we will cancel the appointment and let you know by text and email
Lets us know how the appointment goes.
Take care.
Kath_F
