Just browsing
Message 1 of 5
Intermittent connectivity problems
Occasionally getting drops in connection meaning I need to reset my router.
Looking through the logs I am getting a number of 'No Ranging Response received - T3 time-out' messages. Reading through other posts, it looks like the downstream power levels look on the low side?
Here are the stats from my router logs:
1723000000-8.538256 qam40
2539000000-6.738256 qam17
3547000000-6.938256 qam18
4555000000-7.238256 qam19
5563000000-738256 qam20
6571000000-738256 qam21
7579000000-7.538256 qam22
8587000000-838256 qam23
9595000000-7.738256 qam24
10603000000-838256 qam25
11611000000-8.738256 qam26
12619000000-8.738256 qam27
13627000000-8.438256 qam28
14635000000-8.737256 qam29
15643000000-8.937256 qam30
16651000000-8.538256 qam31
17659000000-8.238256 qam32
18667000000-8.537256 qam33
19675000000-8.737256 qam34
20683000000-8.537256 qam35
21691000000-8.238256 qam36
22699000000-8.738256 qam37
23707000000-937256 qam38
24715000000-8.738256 qam39
1Locked38.690
2Locked38.9120
3Locked38.600
4Locked38.920
5Locked38.660
6Locked38.970
7Locked38.660
8Locked38.930
9Locked38.640
10Locked38.680
11Locked38.610
12Locked38.6120
13Locked38.650
14Locked37.660
15Locked37.690
16Locked38.690
17Locked38.970
18Locked37.680
19Locked37.620
20Locked37.660
21Locked38.950
22Locked38.660
23Locked37.660
24Locked38.6100
15369999847.5512064 qam10
23940000447.5512064 qam12
34619995947.5512064 qam11
46030003447.5512064 qam9
15/11/2020 21:35:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 04:02:10noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 04:02:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 03:32:10noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 03:32:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 08:19:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 15:32:10noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 15:32:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 15:02:10noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 15:02:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 14:32:10noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 14:32:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 04:01:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 02:32:10noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 02:32:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 09:35:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 06:31:44noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 06:31:44ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Please can anyone advise if the power levels are the issue?
Thanks!
  • 4.42K
  • 749
  • 1.8K
Message 2 of 5
Re: Intermittent connectivity problems
You are correct downstream power levels are far too low.  I'll flag that for the forum staff to advise on, but be prepared that they're very busy at the moment so response may take a while (unless luck is on your side).
  • 3.62K
  • 215
  • 277
Message 3 of 5
Hi honker,
Thanks for posting and welcome to our community 🙂
I'm sorry to see you're having some issues with the connection.
I've been able to locate your account using your forum details, I can see the hub is having some prolonged signal level issues, this is something I'll need to arrange a technician for.
You can view the time and date of your appointment here
Alex_Rm
Just browsing
Message 4 of 5
Thanks for getting back so quickly! I can't see anything under 'My Orders', will it take 24 hrs to show?
  • 3.62K
  • 215
  • 277
Message 5 of 5
No worries at all 🙂
I'll pop you over a private message to let you know the appointment details.
Alex_Rm
