Intermittent connection
ellisb51
My broadband runs generally fine (set up a TB quality monitor and there are no real issues). It seems to be an issue with dropping Wi-Fi connections to various devices. The wired connections are fine. Often on iPhone and iPad the wheel is left spinning and then when it does connect there is often no internet. This happens very regularly (every 20 mins) at all times of the day and has been going on for around a month.
I have done all the recommended actions and am now out of ideas. Any help much appreciated.
see router stats below
34 REPLIES 34
Tom_F
Sorry to hear about the ongoing issues ellisb51. I've taken a closer look into this today, and can see there may be an issue with the downstream power levels - at the moment they are considered within spec, but with natural fluctuations which can be expected that may be causing the problems you've been experiencing.
I can arrange for a follow-up visit with a senior technician who will take extra time to check everything over - please get back to me via PM and we'll be able to get that arranged for you.
Tom
Update: Engineer fitted a test hub alongside (split) with normal hub and advised to only connect one device to his test hub to check if anything internally was causing the drops.
My question is: on the original hub: there are still 1000's of POST RS ERRORS on every channel downstream and lots of T3 timeouts - can this be caused by internal devices? - e.g. if a games console downloading a large file - or are these external factors only relying on VM network?
Even on the test hub there are T3 timeouts occurring on each upstream channel - and only one device (my iPhone) is connected to this.
Any help with this much appreciated.
Hi ellisb51,
Can you confirm if you are still having issues with the services?
Can see the hubs not been rebooted since your engineer visit if you're able to try that?
Alex_Rm
Update: just had another disconnection while on Teams again - this cannot happen anymore.
The engineer fitted a test hub which ran fine with just one device connected. The original (still a replacement) is now disconnecting again for 5 min bursts.
5 engineer visits (ridiculous) have not been able to find any issue - and I'm told also on the network.
At this point I am extremely frustrated - why can nothing be done about this?
See BQM -
https://www.thinkbroadband.com/broadband/monitoring/quality/share/eb89511fbffb532e0e83e0e4e20f98e68546b77b
Not sure why most is red - then goes back to normal graph after the disconnection?
This is what I have on router page during disconnection:
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
331000000
7
40
256 qam
25
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.9
0
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
53699974
46.8
5120
64 qam
10
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
Time
Priority
Description
20/09/2021 21:35:11
critical
20/09/2021 21:29:55
notice
DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/09/2021 21:29:55
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2021 13:28:51
critical
17/09/2021 03:43:52
notice
17/09/2021 03:43:52
Error
15/09/2021 11:35:56
critical
Hi there @ellisb51
Thank you so much for your updates and I am so sorry that this is ongoing. I can fully understand how frustrating this must be.
Can I just ask are you only experiencing these disconnections now on the one device during Teams, or do disconnections still happen on all devices, both wired and WiFi?
Thank you again.
