Hayley_S
  • 2.53K
  • 84
  • 180
Message 11 of 35
Re: Intermittent connection
Hello @ellisb51,
Welcome back to the community page, thank you for posting on here.
I am sorry to see that your connection is intermittent, I have checked your account and I can not see any known issues with your upstream or downstream, there is no area outages affecting your service either.
Are you able to do a pinhole reset for me? Also have you set up a BMQ chart already?
Look forward to your response.
Hayley
ellisb51
  • 37
Message 12 of 35
Hi Hayley,
The stats are back to normal now as I reset the hub an hour ago, but I can’t keep doing this every time the internet fails.
in addition I have factory reset the hub a number of times over the past few weeks and the issue still persists.
The BQM shows Outage all night until I reset the router this morning:
<a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/62a1c78911f3a764cf1692994fed9325b930e90f-01-08-2021"><img alt="My Broadband Ping - VIRGIN 5TS23 QUALITY" src="https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/62a1c78911f3a764cf1692994fed9325b930e90f-01-08-2021.png" /></a>
Hayley_S
  • 2.53K
  • 84
  • 180
Message 13 of 35
Thank you for doing that for me @ellisb51.
I was unable to load up anything from that link, please can you send me the URL directly? E.G a link?
Many thanks,
Hayley
ellisb51
  • 37
Message 14 of 35
Apologies, as i was using phone.
See correct link here:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/db3b469e5494ce1bbab2adb3fc9408ab08d1dbec
Hayley_S
  • 2.53K
  • 84
  • 180
Message 15 of 35
Thank you for sharing this link @ellisb51.
I can see it is mostly red, was your Hub off at this time? Is your BMQ chart set up correctly?
Is this a Live BMQ chart or is this from a different day?
Many thanks,
Hayley
ellisb51
  • 37
Message 16 of 35
@Hayley_S No the hub has only been restarted once today (otherwise the hub is on 24/7/365) - this is the problem. The BQM is set up correctly, yes.
Thanks.
Gareth_L
  • 8.34K
  • 486
  • 930
Message 17 of 35
Can you please reboot the hub and run a test for 24 hours ellisb51
Gareth_L
ellisb51
  • 37
Message 18 of 35
Apologies, I’ve rebooted (and reset) the hub a number of times now, the problem always comes back.
I need a permanent fix - and rebooting the hub does not fix this issue permanently.
Gareth_L
  • 8.34K
  • 486
  • 930
Message 19 of 35
Thanks ellisb51
I am able to look at getting a Technician out to chak things for you
Let me know if you wish to go ahead
Gareth_L
ellisb51
  • 37
Message 20 of 35
Hi Gareth I have monitored for a few more days but there’s still constant disconnections on my iPad etc.
please review the BQM below and advise.
but yes as long as technician visit is no charge I would like to go ahead as currently am paying for a service that is not available 100% of the time.
thanks
