andrew_butter
  • 21
Message 1 of 7
Intermittent connection.
I've got my SH3 in modem mode and I'm using an amplifiHD as my router. Since about two days ago I seem to be getting really bad connection issues/packet loss?
The SH3 has a constant red light on the front, I know some people say it should be purple? It is for sure red and not purple. Ive moved it so its not overheating and it seems cold to the touch after leaving it off for some time.
When my internet is working, its working perfectly, but it keeps ping spiking in games from around 27MS to 600-1000MS. I've not changed anything in my house and have done all the basic checks such as connections and rebooting/resetting via the pin hole.
I have tried the virgin media fault checker and calling but both got me no where telling me there is no fault when there clearly is.
I have uploaded my up and down streams. I'm pretty sure there is meant to be 4 upstream but I'm only seeing one not sure if this is a cause for the drop outs?
1331000000-1.540256 qam25
2203000000-1.240256 qam9
3211000000-1.540256 qam10
4219000000-240256 qam11
5227000000-3.240256 qam12
6235000000-240256 qam13
7243000000-1.240256 qam14
8251000000-1.540256 qam15
9259000000-1.740256 qam16
10267000000-1.740256 qam17
11275000000-1.740256 qam18
12283000000-1.740256 qam19
13291000000-1.740256 qam20
14299000000-1.540256 qam21
15307000000-1.740256 qam22
16315000000-1.540256 qam23
17323000000-1.740256 qam24
18371000000-240256 qam26
19379000000-2.240256 qam27
20387000000-2.440256 qam28
21395000000-2.540256 qam29
22403000000-2.540256 qam30
23411000000-2.738256 qam31
24419000000-340256 qam32
15370014649.5512016 qam10
andrew_butter
  • 21
Message 2 of 7
Re: Intermittent connection.
After restarting and plugging in a different attenuator I now have all 4 channels again? Not sure if they are here to stay or not however
1 53699708 49.5 5120 16 qam 10
2 60300129 49.5 5120 16 qam 9
3 39399896 49.5 5120 16 qam 12
4 32600056 46.5 5120 16 qam 13
gary_dexter
  • 30.24K
  • 1.87K
  • 4.02K
Message 3 of 7
They’re out of spec as they should be 64QAM not 16QAM.
andrew_butter
  • 21
Message 4 of 7
What's the solution? Do I need an engineer or is this something that can be sorted myself? I've just had another 15 minute full dropout since my post
andrew_butter
  • 21
Message 5 of 7
Just had another disconnection, checked the service checker and it now says virgin are aware of an issue in my area. Hopefully that will fix the issue. Trying to work from home and this is looking extremely unprofessional on my side....
gary_dexter
  • 30.24K
  • 1.87K
  • 4.02K
Message 6 of 7
If there’s a known issue you’ll have to wait til it’s resolved.
If broadband is imperative for home working then look into getting a backup dsl link and/or a 4G/5G router as backup.
Residential services don’t cover home working.
Megan_L
  • 2.36K
  • 146
  • 234
Message 7 of 7
Hi Andrew_Butter,
Thanks for your post, I am sorry you're having this issue with your broadband services recently.
I have had a look at your services on my side and can see there is an area outage, which is regarding an SNR issue.
This is due to be fixed  - 05 MAY 2021 9am - but please be aware this is just an estimate, it could change depending on what the engineers find. However, I am sure they will be working incredibly hard to get this fixed as soon as possible for you.
Please continue to come back to us in order to get an update on this if you wish.
Megan_L
