  • 464
  • 24
Up to speed
Message 1 of 11
Intermittent connection
Had a intermittent connection since yesterday afternoon (Thursday 22 October) - I should get 200+ but get only between 6 to 40 - is there a problem on VM?
  • 15.25K
  • 1.2K
  • 3.58K
Message 2 of 11
Re: Intermittent connection
post some info
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labelled - upstream - downstream
if its an earlier hub button is top right
are you seeing slow speeds on both wired and wireless connections
____________________
Tony
  • 25.16K
  • 1.44K
  • 3.21K
Message 3 of 11
Are you measuring speeds wired or wireless?
  • 464
  • 24
Up to speed
Message 4 of 11
Both, wired varies between 40 & 223 and wireless is not going above 10. I was wondering more is there a outage on VM; the same happened last Sunday afternoon for a few hours also...
  • 15.25K
  • 1.2K
  • 3.58K
Message 5 of 11
there may be a local problem - you can ring and see if there is anything known - Service Status number - 0800 561 0061 - which usually tells you of more local issues down to postcode level
post the info as asked that will say if its anything on your input thats wrong
Tony
  • 464
  • 24
Up to speed
Message 6 of 11
All back to normal as of 11am today (Friday 23 October) - must have been a outage somewhere in area 15
  • 464
  • 24
Up to speed
Message 7 of 11
went again mid-afternoon (Friday 23 October)
  • 15.25K
  • 1.2K
  • 3.58K
Message 8 of 11
post the levels as asked above
Tony
  • 464
  • 24
Up to speed
Message 9 of 11
all ok again
  • 25.16K
  • 1.44K
  • 3.21K
Message 10 of 11
it’s pointless posting when things are down and fixed again without posting stats
