  • 22
Message 1 of 33
Intermittent connection
Having issues with internet. Have to often reboot modem to 'fix' connection, and when its fixed I only get 80Mbps up out of 200Mbps(used to be 160Mbps but apparently I got an upgrade?). The upload seems fine. Here's the BQM graph and logs:
My BQM
Downstream  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)139000000147000000155000000163000000171000000179000000187000000195000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID12345678
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)-1.77-1.51-1.11-0.84-0.67-0.85-0.93-1.25
RxMER (dB)36.1736.3936.3936.3937.3637.0936.8437.09
Pre RS Errors
13374350952036169538450020911444
Post RS Errors
442328427275289317315
941
Upstream  US-1 US-2 US-3 US-4
Channel Type2.02.02.02.0
Channel ID5423
Frequency (Hz)32600000394000005370000046200000
Ranging StatusSuccessSuccessSuccessSuccess
Modulation64QAM64QAM64QAM64QAM
Symbol Rate (Sym/sec)5120000512000051200005120000
Mini-Slot Size2222
Power Level (dBmV)45.0045.7549.0046.75
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0000
T4 Timeouts000
0
First TimeLast TimePriorityError NumberDescription
04/09/2020 13:40:50 GMT04/09/2020 13:40:50 GMTError (4)68010302DHCP WAN IP - **.**.**.**
04/09/2020 13:39:46 GMT04/09/2020 13:39:46 GMTError (4)68000407TOD established
Time Not EstablishedTime Not EstablishedNotice (6)84000510Downstream Locked Successfully
04/09/2020 12:17:12 GMT04/09/2020 12:17:12 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
04/09/2020 12:16:38 GMT04/09/2020 12:16:38 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
04/09/2020 12:16:34 GMT04/09/2020 12:16:34 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
04/09/2020 12:16:32 GMT04/09/2020 12:16:32 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
04/09/2020 12:10:06 GMT04/09/2020 12:10:06 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
04/09/2020 12:10:01 GMT04/09/2020 12:10:01 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
04/09/2020 12:09:52 GMT04/09/2020 12:09:52 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
04/09/2020 12:09:47 GMT04/09/2020 12:09:47 GMTWarning (5)84020200Lost MDD Timeout
04/09/2020 12:09:46 GMT04/09/2020 12:09:46 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
04/09/2020 12:09:45 GMT04/09/2020 12:09:45 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
04/09/2020 12:09:44 GMT04/09/2020 12:09:44 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
04/09/2020 12:09:43 GMT04/09/2020 12:09:43 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
04/09/2020 12:09:40 GMT04/09/2020 12:09:40 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
Experienced issues to do with power levels in the past, guessing that's what it is currently as well. Any help would be much appreciated.
27/08 31/08
  • 6.42K
  • 475
  • 841
Hero
Message 2 of 33
Re: Intermittent connection
Your >> BQM << is showing a lot of latency and your Hub stats don't look to bad to me.
I think your problem may be on the other side of the Hub, possibly SNR or over utilisation.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 15.5K
  • 1.62K
  • 2.64K
Message 3 of 33
Your Hub stats look ok but the logs dont. can you set up a BQM as per below then we can compare the BQM over the same 24h period as the Logs.
You have the SH2 (same as me) have you considered the free upgrade to the Hub3 - it "might" help as it uses more downstream channels to connect - but not if there is fault on the network connection of course.
A pinhole reset of the Hub "might" help but will clear any settings you put in and revert the SSID's and 2 passwords to those on its base sticker - so make sure the sticker still there and legible first !
Set up a free “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” (as per instructions on the TB website) when you have the first 24h period.
  • 22
Message 4 of 33
  • 15.5K
  • 1.62K
  • 2.64K
Message 5 of 33
That BQM looks fine to my eyes - just the off-time between ~1.30-3.30 this aft - was that just you switching it off?
  • 6.42K
  • 475
  • 841
Hero
Message 6 of 33
John; that is yesterdays BQM.
I think this is the live one > > BQM <<
Mike Robinson
  • 15.5K
  • 1.62K
  • 2.64K
Message 7 of 33
Good spot Mike 🙂
The latest one also looks fine to me.
  • 22
Message 8 of 33
Yeah I switched everything off to move my desk.
  • 22
Message 9 of 33
I'm more inclined to believe the graph shows a lot of latency rather than it being fine. My connection is anything but fine, its running at ~half speed and is unstable.
  • 6.42K
  • 475
  • 841
Hero
Message 10 of 33
Can you carry out a couple of speed tests at speedtest.net using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected.
Ensure that the Network Interface Card (NIC) drivers are up to date.
Then post the links to the results on here
Mike Robinson
