Lukenorth
Intermittent connection issues
I'm having issues with my broadband, where sometimes the connection is perfectly fine and getting the advertised download speeds, but then at other times I have very slow wifi or no WiFi connection at all in certain areas of the house.
I had the same issue around a month ago and it was resolved, some kind of power issue, but now the issue has come back.
Any help would be appreciated.
  • 35.14K
  • 3.42K
  • 6.69K
Re: Intermittent connection issues
See this
________
Are the issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
What Hub model is it? What are the various Hub lights showing/doing when this happens if a Hub3 is the base light a steady white(ish) or flashing green?
Lukenorth
Hi John thanks for the response.
We don't have any devices connected by ethernet so I couldn't say. Most of the time it's a steady white light....when the wifi is off/slow if I get closer to the hub internet seems to pick back up again.
Ashleigh_C
  • 5.38K
  • 198
  • 395
Hi there @Lukenorth
Thank you so much for your post and welcome back to the community forums, it's great to have you here.
I am so sorry that you have faced this issue with your connections. I have taken a look on our side and I cannot see anything that could be causing these issues.
Can I ask how things have been since your last post?
Ash_C
