  • 8
Message 1 of 11
Intermittent connection issue
Currently experiencing intermittent connection issues (wifi and wired), connection drops almost as if router reboots itself.  Wifi will become visible again after about 30 seconds.
Here is router logs as I've seen in other posts.
DOWNSTREAM
1258750000-0.938256 qam16
2250750000-1.238256 qam15
3266750000-0.738256 qam17
4274750000-0.438256 qam18
5282750000-0.538256 qam19
6290750000-0.438256 qam20
7298750000-0.238256 qam21
8306750000-0.538256 qam22
9314750000-0.238256 qam23
10322750000038256 qam24
11330750000038256 qam25
123787500000.738256 qam26
133867500000.538256 qam27
143947500000.738256 qam28
154027500000.738256 qam29
164107500000.738256 qam30
174187500000.938256 qam31
18426750000138256 qam32
19434750000138256 qam33
20442750000138256 qam34
214507500000.738256 qam35
224587500001.438256 qam36
23466750000138256 qam37
244747500000.938256 qam38
1Locked38.63963
2Locked38.9430112
3Locked38.91260
4Locked38.91040
5Locked38.9790
6Locked38.61180
7Locked38.6860
8Locked38.91470
9Locked38.9920
10Locked38.6800
11Locked38.6680
12Locked38.6790
13Locked38.91000
14Locked38.6870
15Locked38.91220
16Locked38.91270
17Locked38.9390
18Locked38.6810
19Locked38.91060
20Locked38.91060
21Locked38.9620
22Locked38.9430
23Locked38.9560
24Locked38.9610
16030000051512064 qam1
23940002051512064 qam4
34620002951512064 qam3
45370000051512064 qam2
1ATDMA0030
2ATDMA0010
3ATDMA0020
4ATDMA0000
  • 8
Message 2 of 11
Re: Intermittent connection issue
18/11/2020 08:47:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/11/2020 07:06:17ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 16:45:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 23:29:46noticeNOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 23:15:2noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 17:38:51ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 09:46:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 09:46:41noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 09:46:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 09:46:27Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 09:42:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 09:14:59noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 09:14:41Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 02:04:29noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 02:04:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 02:03:42noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 01:58:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 01:52:35criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 01:50:22Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 8
Message 3 of 11
https://www.thinkbroadband.com/broadband/monitoring/quality/share/1cecd8cfe419b9b111e4a7d7f10eb312c3...
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/1cecd8cfe419b9b111e4a7d7f10eb312c3eab84b][img]https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/1cecd8cfe419b9b111e4a7d7f10eb312c3eab84b.png[/img][/url]
  • 8
Message 4 of 11
  • 8
Message 5 of 11
Post over a week old and not one response?
Is this normal?
  • 25.12K
  • 1.44K
  • 3.2K
Message 6 of 11
Is this normal?
It can be yes.
Anyway your upstream levels are too high and you’ll need an engineer
  • 12.23K
  • 947
  • 1.57K
Message 7 of 11
The 5 to 7 days isn't fixed in stone and it seems to be timed from the last time the OP posted.
Mike Robinson
  • 8
Message 8 of 11
Getting worse now, constantly having to reset router 😡
  • 12.23K
  • 947
  • 1.57K
Message 9 of 11
Have you phoned in as Gary advised.
Your connection / Hub will not improve until VM have done their stuff.
Mike Robinson
  • 8
Message 10 of 11
I'd love too, but after being on online chat for 4 hours, to then be told to ring the call center which then said "we're too busy to take your call, please call back tomorrow" it's a little difficult.
I will keep trying I guess
