Message 1 of 10
Intermittent connection hub 3
There was an outage in my area yesterday because of which my broadband, TV were affected for the day. My service status shows that all the services were restored yesterday in the evening however since then I have been facing intermittent internet connectivity issue. The internet is connected is for a few mins and suddenly gets disconnected with the hub showing different lights flashing on the front. This happens at least 4-5 times in an hour and I am unable to work from home. I have tried rebooting the hub as well as reset the hub multiple times, have checked all wires connected but the problem persists. What is frustrating is when I call the customer care number it cuts off after waiting for 45 mins. I have tried your webchat option as well but except for an autobot reply no one has been able to help. I feel helpless as the problem continues and I don't know how to fix it. I am a new customer and this is a frustrating experience. Please help out.
  • 11.36K
  • 888
  • 1.45K
Message 2 of 10
Re: Intermittent connection hub 3
Try a reboot to see if the Hub can renegotiate a better connection using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your connection again.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
Message 3 of 10
I tried rebooting as per the advice. However the problem is still not resolved. Is there anything else that can be done to fix this issue.
  • 11.36K
  • 888
  • 1.45K
Message 4 of 10
Then
Can you please
Mike Robinson
Message 5 of 10
My BQM
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
402750000
-22.3
27
256 qam
30
2
202750000
-18.5
30
256 qam
9
3
210750000
-18.9
30
256 qam
10
4
218750000
-19.4
30
256 qam
11
5
226750000
-19.5
29
256 qam
12
6
234750000
-20.9
28
256 qam
13
7
242750000
-22.7
27
256 qam
14
8
250750000
-22.5
27
256 qam
15
9
258750000
-21
28
256 qam
16
10
266750000
-20.5
29
256 qam
17
11
274750000
-20.8
29
256 qam
18
12
282750000
-20.4
29
256 qam
19
13
290750000
-20
29
256 qam
20
14
298750000
-19.9
29
256 qam
21
15
306750000
-20
29
256 qam
22
16
314750000
-20.4
29
256 qam
23
17
322750000
-19.5
29
256 qam
24
18
330750000
-19.8
29
256 qam
25
19
370750000
-20.2
29
256 qam
26
20
378750000
-22
27
256 qam
27
21
386750000
-23.4
27
256 qam
28
22
394750000
-22.8
27
256 qam
29
23
410750000
-22
27
256 qam
31
24
418750000
-23
27
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
27.8
6773595
19478
2
Locked
30.6
592840
0
3
Locked
30.3
974385
0
4
Locked
30
1373849
0
5
Locked
29.8
1977422
0
6
Locked
28.9
3887378
1
7
Locked
27.6
5496669
59873
8
Locked
27.7
5490440
18293
9
Locked
28.6
4407109
3
10
Locked
29.2
3182630
0
11
Locked
29.2
3243678
0
12
Locked
29.4
2677453
0
13
Locked
29.6
2063283
0
14
Locked
29.3
2706190
0
15
Locked
29.4
2522755
0
16
Locked
29.2
2965481
0
17
Locked
29.7
1875890
0
18
Locked
29.7
2018475
0
19
Locked
29.2
3027219
0
20
Locked
27.7
5497409
24331
21
Locked
27
4760355
868641
22
Locked
27.3
5421772
189758
23
Locked
27.6
5511532
45515
24
Locked
27.3
5346767
272365
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
46200000
5.4
5120
32 qam
3
2
39400000
5.396
5120
16 qam
4
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
Time
Priority
Description
23/10/2020 19:57:44
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 19:57:26
Error
Service Add Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 19:57:8
Warning!
23/10/2020 19:57:3
Error
DCC rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 19:57:0
Warning!
23/10/2020 19:56:46
Error
23/10/2020 19:55:20
Warning!
23/10/2020 19:52:44
critical
23/10/2020 19:51:41
Warning!
23/10/2020 19:51:38
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 19:51:24
Warning!
23/10/2020 19:51:22
Error
Service Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 19:51:15
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 19:50:18
Warning!
23/10/2020 19:50:18
Error
23/10/2020 19:48:58
Warning!
23/10/2020 19:48:52
Error
23/10/2020 19:46:30
Warning!
23/10/2020 19:43:48
critical
23/10/2020 19:34:20
Warning!
  • 11.36K
  • 888
  • 1.45K
Message 6 of 10
Your Hub Power Levels are all over the place and will need an engineer to put right.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Mike Robinson
  • 24.31K
  • 1.39K
  • 3.09K
Message 7 of 10
Downstream too low and upstream too high.
Unless there’s an area issue reported you need an engineer for sure.
Message 8 of 10
Thank you for your help in identifying the issue. How do I book an engineer visit? Do I need to do anything for one of your VM forum engineer to come along to fix the issue?
  • 11.36K
  • 888
  • 1.45K
Message 9 of 10
See Post #6
Mike Robinson
  • 1.64K
  • 96
  • 164
Message 10 of 10
Hello Svshahare,
Thanks for using the forums to get this issue with your internet looked into, I am sorry if this has been causing some frustration.
I have already taken the time to look into your services on my side and can see there is an area outage at the moment which is having an adverse affect on your broadband, TV and landline, however this is estimated to be fixed today by 6pm tonight.
I am of course not saying this is the cause of your original issue, but we will need to wait until this outage is fixed fully before investigating further.
Please check back in tomorrow and we will be happy to look into it further for you 🙂
Thanks for your patience.
Megan_L
