Intermittent connection for > 1 year
Hi everyone, I've had terrible intermittent connection issues for a long time now. Now the problems are so severe that I can't even have a zoom meeting on WiFi - having to use my 4g data. As you can imagine this is extremely frustrating. Would someone on here please be kind enough to help and see if this is a wiring issue or a router issue?
Here are my network stats:
Downstream  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)138750000146750000154750000162750000170750000178750000186750000194750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID12345678
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)-0.78-0.71-0.70-0.75-0.76-0.94-1.40-1.43
RxMER (dB)36.1736.1736.3936.1736.6136.8436.3936.17
Pre RS Errors8121676393366321298311306
Post RS Errors305277285283320293302299
Upstream  US-1 US-2 US-3 US-4
Channel Type2.02.02.02.0
Channel ID4235
Frequency (Hz)39400000537000004620000032600000
Ranging StatusSuccessSuccessSuccessSuccess
Modulation64QAM64QAM64QAM64QAM
Symbol Rate (Sym/sec)5120000512000051200005120000
Mini-Slot Size2222
Power Level (dBmV)43.0043.0043.0043.00
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0000
T4 Timeouts0000
Thank you!
  • 11.9K
  • 926
  • 1.53K
Re: Intermittent connection for > 1 year
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Disable any VPNs that you have running.
Mike Robinson
Hi, thanks for your reply. Here is My BQM
