on 09-05-2023 12:35
I am in the same boat as ScottG99. A good three months of intermittent broadband. Engineers been out twice, equipment has been replaced and every time I call (which has probably used up 10 hours so far) I’m told the same thing - wait 24 hours. Online checks keep telling me it’s temporary (which it clearly isn’t) and no one offers any advice or solutions, aside from putting on hold and transferring to another department. Can someone from Virgin please contact me to explain how they are going to fix this.
on 11-05-2023 13:22
Hey @Evs1,
Welcome to the Community Forums and thanks for the post.
Sorry to hear you have been experiencing this issue, having checked into our systems I can see you have a technician appointment booked in for today, this should help to rectify the issue or at least provide further information as to what is causing this, please let us know how this visit goes and if further assistance is needed we can provide this.
Cheers. Joe
on 11-05-2023 13:49
Thanks Joe,
yes the engineer came and went. He could see that in that in the last month there around 250 drop outs with a total loss of service being a day and something. He did something outside the house and thought it had fixed the issue, but it dropped again about 10 minutes after he left so the problem still persists. Where do we go from here? It’s starting to wear a bit thin. Especially I noticed a £20 monthly increase in my bill this month!!!
on 11-05-2023 16:19
OK time to see some data - can you do this - especially the BQM
______________________________________________________
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
on 13-05-2023 16:33
Hi @Evs1 thanks for your reply, although we're sorry to hear that the engineer visit didn't resolve things as we were hoping.
As @jbrennand has mentioned, if you could kindly provide your Hubs logs as requested, and we can take things from there for you?
Many thanks
on 16-05-2023 15:39
Thanks Tom and @jbrennand - data below requested. An ideas from here appreciated!
1 291000000 4 38 256 qam 20
2 139000000 5 38 256 qam 1
3 147000000 5.3 38 256 qam 2
4 155000000 5.5 38 256 qam 3
5 163000000 5.4 38 256 qam 4
6 171000000 5 38 256 qam 5
7 179000000 4.8 38 256 qam 6
8 187000000 4.9 38 256 qam 7
9 195000000 4.9 38 256 qam 8
10 203000000 5 38 256 qam 9
11 211000000 4.8 38 256 qam 10
12 219000000 5 38 256 qam 11
13 227000000 5 38 256 qam 12
14 235000000 4.8 38 256 qam 13
15 243000000 4.4 38 256 qam 14
16 251000000 4.3 38 256 qam 15
17 259000000 4.3 38 256 qam 16
18 267000000 4.5 38 256 qam 17
19 275000000 4.4 38 256 qam 18
20 283000000 4.1 38 256 qam 19
21 299000000 4.5 38 256 qam 21
22 307000000 4.1 38 256 qam 22
23 315000000 4.3 38 256 qam 23
24 323000000 4 38 256 qam 24
1 Locked 38.9 0 0
2 Locked 38.9 0 0
3 Locked 38.9 0 0
4 Locked 38.6 5 0
5 Locked 38.9 6 0
6 Locked 38.9 0 0
7 Locked 38.6 0 0
8 Locked 38.9 0 0
9 Locked 38.9 0 0
10 Locked 38.9 6 0
11 Locked 38.9 0 0
12 Locked 38.9 6 0
13 Locked 38.9 6 0
14 Locked 38.9 4 0
15 Locked 38.6 0 0
16 Locked 38.9 0 0
17 Locked 38.9 0 0
18 Locked 38.9 4 0
19 Locked 38.6 5 0
20 Locked 38.9 0 0
21 Locked 38.9 5 0
22 Locked 38.9 5 0
23 Locked 38.9 0 0
24 Locked 38.9 0 0
1 49599988 45.8 5120 64 qam 1
2 23600048 42.3 5120 64 qam 5
3 30099998 43.3 5120 64 qam 4
4 36600000 44.3 5120 64 qam 3
5 43100012 45.8 5120 64 qam 2
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
5 ATDMA 0 0 0 0
11/05/2023 13:22:4 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2023 13:10:19 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2023 13:08:49 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2023 13:07:56 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2023 13:07:52 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2023 13:07:52 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2023 13:07:48 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2023 13:02:21 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2023 13:02:21 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2023 13:01:59 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2023 12:59:31 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2023 12:59:26 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2023 12:59:26 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2023 12:59:25 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2023 12:59:14 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2023 12:58:18 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2023 12:58:14 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2023 12:58:13 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
on 18-05-2023 16:33
Hey @Evs1,
Thanks for getting back to us with that.
What I have actioned the system to do is monitor your services for the next 24 hours, we ask you to do the same, let us know if the service remains the same or if it gets better during this period, we also ask to make sure you have performed a reboot of the Hub recently.
Cheers. Joe
on 18-05-2023 16:40
Thanks Joe
that has been tried several times with exactly the same result. Pretty much the definition of madness! It’s been monitored for 24hrs with with the promise of improvement which doesn’t come. The hub has been rebooted multiple times. It has been replaced altogether and then rebooted too so feel like those boxes are ticked! Any other suggestions please?
cheers
james
on 18-05-2023 16:49
Dont think you have actually said but...
… are the issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
on 18-05-2023 18:09
Thanks John,
no it’s not the hub as Ethernet has same issue. The hub has also been changed over so unless just very unlucky in getting two dud hubs I think it’s unlikely?
