FairwayJesus
  • 6
Message 1 of 9
Intermittent connection drop outs
Hi all,
We recently moved to a new house in August last year. VM gigabit package installed as it was easily the best speed and deal avaliable in the area. We had no issues for a couple of months but just before Xmas 30 second drop outs of all connection wired or wireless started to occur. I've had 3 engineers out to look at it, between them they have changed the cable from Box at top of road to our house and all cabling inside our house. I've been told that the TP router i was using could be the problem so i've put my HUB4 back into router mode. Still the same issue.
I've set up a BQM (link below) after reading some posts about overutilisation in the area. Not sure how to see that from the graph (any help apprecaited). I can post Status logs if that would be useful?
https://www.thinkbroadband.com/broadband/monitoring/quality/share/bfb552a7c875ec47d1dbfa15b6feec1bb63f07dd
Any suggestions or help would be really appreciated. VM have the best package and speeds in my area by some way so I dont really want to leave but its at the point where its impacting my work so I have no other choice if it cant be fixed.
Thanks in advance.
FairwayJesus.
FairwayJesus
  • 6
Message 2 of 9
Re: Intermittent connection drop outs
Adding Network log details.
3.0 Downstream channels
14110000002.238.6QAM2561
24190000002.538.6QAM2562
3427000000338.6QAM2563
44350000003.239QAM2564
54430000003.338.6QAM2565
64510000003.238.6QAM2566
74590000003.238.6QAM2567
84670000003.238.6QAM2568
94750000003.438.6QAM2569
104830000003.738.6QAM25610
114910000003.738.6QAM25611
124990000003.739QAM25612
135070000003.739QAM25613
145150000003.938.6QAM25614
155230000004.138.6QAM25615
165310000004.439QAM25616
175390000004.739QAM25617
185470000004.839QAM25618
19555000000538.6QAM25619
20563000000538.6QAM25620
215710000005.238.6QAM25621
225790000005.538.6QAM25622
235870000005.539QAM25623
245950000005.438.6QAM25624
256030000005.338.6QAM25625
266110000005.238.6QAM25626
276190000005.139QAM25627
286270000005.138.6QAM25628
296350000004.938.6QAM25629
306430000004.639QAM25630
316510000004.338.6QAM25631
1Locked38.60537700
2Locked38.60537700
3Locked38.60537700
4Locked38.98326100
5Locked38.60537700
6Locked38.60537700
7Locked38.60537700
8Locked38.60537700
9Locked38.60537700
10Locked38.60537700
11Locked38.60537700
12Locked38.98326100
13Locked38.98326100
14Locked38.60537700
15Locked38.60537700
16Locked38.98326100
17Locked38.98326100
18Locked38.98326100
19Locked38.60537700
20Locked38.60537700
21Locked38.60537700
22Locked38.60537700
23Locked38.98326100
24Locked38.60537700
25Locked38.60537700
26Locked38.60537700
27Locked38.98326100
28Locked38.60537700
29Locked38.60537700
30Locked38.98326100
31Locked38.60537700
3.1 Downstream channels
159964K1840QAM4096759
159Locked414.94020217288860
FairwayJesus
  • 6
Message 3 of 9
3.0 Upstream channels
13010000047.85120 KSym/secQAM6412
22360000047.55120 KSym/secQAM6413
33660000047.85120 KSym/secQAM6411
44310000048.35120 KSym/secQAM6410
54960000048.55120 KSym/secQAM649
3ATDMA0000
4ATDMA0000
5ATDMA0000
3.1 Upstream channels
1410.038.22KQAM8
14OFDMA20053.930
  • 35.07K
  • 3.41K
  • 6.67K
Message 4 of 9
BQM not showing evidence of OU (yet) but red disconnects are a worry,
Have you still got the TP router plugged in in bridge mode? Have you any other kit connected on ethernet ?
See this...
_______________________
There is one other option, there have been several threads on here recently where similar BQM latency/packet loss problems were eventually pinned down to a dodgy piece of connected kit affecting the connection . Bad connectors on ethernet cables and faulty network switches being high on the list of suspects
What I advised was... if you run the BQM for 24h to get a picture of the issues (you have done this) - and then unplug all the ethernet cable connections from the Hub and just let it run - overnight is best - then in the morning look at the BQM and see if it has cleaned up. If it has - plug the devices back in one at a time for an hour or two until the problem reappears and that should indicate where to look for what is causing the issues
Examples.
See message 21 in the first thread - and 13 in the second.
https://community.virginmedia.com/t5/Networking-and-WiFi/Internet-connection-dropping/td-p/4781287/p...
https://community.virginmedia.com/t5/Networking-and-WiFi/Intermittent-Connection/td-p/5069984/page/2
FairwayJesus
  • 6
Message 5 of 9
Thanks for your reply, John.
I'm using the Hub4 in router mode currently so no TP kit attached.
The only device I have connected via ethernet is my desktop PC (& potentially the TV box, will double check).
Thanks for the suggestion about unplugging all and seeing if that fixes the problem, i'll give this a try overnight tonight and hopefully it at least helps me narrow it down!
FairwayJesus
  • 6
Message 6 of 9
Hi John,
Returning here after unplugging everything overnight. Looking at the BQM looks like there is still an issue with the disconnects. Any other suggestions or should I wait for the forumn team to get in touch?
I'm not sure what else an engineer could try? Or if there is a way to esclate this based on 3 engineers already attempting to fix.
FairwayJesus
  • 35.07K
  • 3.41K
  • 6.67K
Message 7 of 9
Not much else you can do without more VM input. But this basic check would be good.
_________________________________
Do a check that all of your coax and ethernet cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking, animal chews or chaffing, check that all looks good with the outside cabling and wall box too - no “staples, etc. piercing the cables.
FairwayJesus
  • 6
Message 8 of 9
Thanks John, done all that you have suggested and still no joy.
Any ideas how long it will take forum staff to get in touch? I dont want to just book another engineer through the App. Ideally an area manager will be involved as the 3 previous engineers have not fixed the issue...
Kain_W
  • 3.72K
  • 102
  • 265
Message 9 of 9
Hi there FairwayJesus,
Thanks for your post and welcome back to the community
Sorry to hear that you're experiencing dropouts with your service, just from checking I can't see any readings currently that would attribute to the issues above.
How is the service since last posting?
Regards,
Kain
