SumotaY
  • 15
Message 1 of 7
Intermittent connection down
Hello,
Since yesterday Friday around midday I am experiencing not stable connection. Every 20-30 minutes the connection goes down (there is no WiFi and no Ethernet connectivity) and it goes back on after 5-10 minutes by itself.
I managed to check the Network logs from the Hub5 and it shows messages like the attached. I checked the status tool to see if there is any current issue in the area and it says there is no issue.
However if I run the connection test, it says there is an issue as in the second attachment (it has been saying to wait for 1 hour since more than 3 hours...).
Can anyone help here? the Internet connection is useless like this.
David.
  • 35.1K
  • 3.41K
  • 6.68K
Message 2 of 7
Re: Intermittent connection down
As well as trying the “check service,”Area status webpage" (link at top right of this forum), also try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues down to postcode level.
SumotaY
  • 15
Message 3 of 7
Thanks John,
Yes, that link you mention goes to the service I have been using. At first it tells me there is no issue in the area:
And after clicking on "Still having issues?" and run the test, shows me the message I mentioned earlier:
I have just called to the number and after confirming my post area, it says there is no issue in the area.
However I am still having problems.
David.
  • 35.1K
  • 3.41K
  • 6.68K
Message 4 of 7
You have the Hub5 - which is not on general release yet - you are effectively testing it for VM. So there may be firmware issues affecting the messages. But as nothing is showing - lets see the connection data - do this
_______________________
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. On the first page up Login and then Navigate to these “pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs page. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again. If character limits are “exceeded” - just do two posts
If you haven’t already, set up a free, secure and “offlsite” - “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph”. Click the lower link (Share Live Graph) then click generate. Copy the text in the Direct Link box, beware, there may be more text than you can see. On here click the Link icon (2 links chain to the left of the camera icon) In the URL box paste the link you copied and then click OK
SumotaY
  • 15
Message 5 of 7
Hi John,
Tables from Downstream:
1306000000-1.440QAM 25622
21380000000.440QAM 2561
31460000000.140QAM 2562
41540000000.139QAM 2563
51620000000.640QAM 2564
6170000000-3.140QAM 2565
71780000000.840QAM 2566
81860000000.540QAM 2567
91940000000.440QAM 2568
102020000000.640QAM 2569
112100000000.440QAM 25610
122180000000.740QAM 25611
132260000000.740QAM 25612
142340000000.840QAM 25613
152420000000.940QAM 25614
162500000000.940QAM 25615
172580000000.940QAM 25616
18266000000-140QAM 25617
19274000000-1.140QAM 25618
20282000000-1.140QAM 25619
21290000000-1.340QAM 25620
22298000000-1.340QAM 25621
23314000000-1.540QAM 25623
24322000000-1.740QAM 25624
25330000000-1.740QAM 25625
26338000000-240QAM 25626
27346000000-240QAM 25627
28354000000-2.140QAM 25628
29362000000-240QAM 25629
30370000000-2.140QAM 25630
31378000000-2.340QAM 25631
1Locked40434720684
2Locked4094512029
3Locked40391416150
4Locked3917043043
5Locked40524717677
6Locked40792219823
7Locked401743640081
8Locked402531748530
9Locked40185311293
10Locked40247016772
11Locked40253717148
12Locked40368221408
13Locked40317419165
14Locked40249114627
15Locked40220414187
16Locked40308519966
17Locked40307319593
18Locked40245313061
19Locked40199912057
20Locked40216216581
21Locked40216016433
22Locked40319714783
23Locked40210016300
24Locked40249416448
25Locked40185016031
26Locked40206715041
27Locked40196714412
28Locked40219915504
29Locked40210214418
30Locked4015979381
31Locked4014979794
Tables from Upstream:
160300000505120QAM 649
25370000049.55120QAM 6410
34620000049.55120QAM 6411
439400000495120QAM 6412
3ATDMA0000
4ATDMA0000
For the Network logs now it shows Internal Error:
Regarding the quality monitor, yes; I saw that an I setup about an hour ago one monitor. Here is the link:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/8c04b1d86bd736c7011bc82fcd5b962f08edb292
  • 35.1K
  • 3.41K
  • 6.68K
Message 6 of 7
I am no expert on Hub5 stats - the Up power levels are on the high side - albeit, in range. but would be woth starting from a blank page to clear the RS errors, as below.
Also - are you in router or modem mode - and what devices are connected to the Hub by ethernet cables?
______________
Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, do a quick check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables.. Then switch the Hub back on and leave ~5 minutes
When all done, check back in the settings and ensure that the RS error counts and T3 errors have all reset to 0. Then check every hour or so to see if they start reappearing - they shouldn't. If they do (particularly the postRS and T3 ones) you have a problem (noise) that only a Tech visit will sort.
SumotaY
  • 15
Message 7 of 7
Hi John,
I am in router mode.
The devices connected vie Ethernet are one desktop computer, one NAS (Synology), one security camera and one Philips Hue bridge. All of them have been connected since I have the router several months ago and there have not been any issues until now.
I have done what you mentioned: switch the hub off, unplug it and wait for 5 minutes. Meanwhile I checked the coax connection and it is firmly connected. Anyway I unscrew it and hand screw it again to make sure. Also I checked the wall box and it is in right conditions.
I have just turn it back on and will see how it goes. However I managed to schedule a VM technician to come over on Monday morning; hopefully either the issue will be fixed in the next hours or the technician will do.
Thanks.
