Diesel88
Intermittent broadband - slow speeds - terrible wifi
Absolutely sick to death of Virgin and their inability to sort out their service.
For months I have experienced very varied WiFi speeds, everyday it fluctuates from 213mb/s download to 1.75mb/s download.  It constantly drops wifi signal, several times a day.
Yes - I have turned it off and on and reset the hub. Sometimes that works, sometimes not.  If it does work it is for a day at max.
Engineer has been and turned up and turned down the signal.  Mucked about in the street and reset the hub and replaced splitters.  Still rubbish.
Last conversation I managed to have with customer support was a promise that an technician would call inside 4 hours.  That was 7 days ago.
I am paying for m200 but not getting it.  This is unacceptable.  Next step is ofcom and leaving.
If by some miracle someone who works for Virgin reads this and gets in contact, please do ask if I have reset or checked local service status.
  • 20.53K
  • 2.18K
  • 3.63K
Re: Intermittent broadband - slow speeds - terrible wifi
Flaky wifi is sometimes just due to a loose connection somewhere can you do do a quick check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box.
What do you get when connected on ethernet cable, and is that stable ?
If you think that you have a BB speed problem, then to check the speeds coming in to your Hub properly, and whether they match what you should be getting, you cannot rely on wifi tests, - no BB supplier guarantees those - only speeds "TO" the Hub are guaranteed.
So, can you test speeds directly like this. As you expect >100Mbps then connect a 1GB enabled computer/laptop, with up to date drivers, via a known good and working Cat5e (or better) ethernet cable, directly to the Hub which you have put into “modem mode” (see VM website for “How To”). Test at speedtest.net (not using their App!) to your nearest VM server - try on 2 different browsers.
If they are still low – boot the device into safe+networking mode and try again.
There are many posts on here where unknown/flaky software, old network card drivers, corrupted browsers or other connected devices are limiting speeds on tests.
Report back what that gets.
