on 04-04-2023 17:39
Hi all,
Unfortunately we have seen a repeat of an earlier issue which is causing intermittent broadband connectivity problems for some Virgin Media customers. We apologise again to those impacted our teams are continuing to work flat out to find the root cause of the problem and fix it.
Regards,
Community Moderator Team
on 04-04-2023 18:37
Issue looks to be VM-->Liberty Global nodes. Continual BGP updates, same as overnight. Red in this graphic is not good.
on 04-04-2023 18:39
Virgin just sent me a private message! I thought wow, a comment on today's shambles. It's better than that
"Congratulations! You have a new rank in the Virgin Media Help & Support Community"
This makes up for everything. I cannot work properly and my kids are driving me nuts because some things refuse to work. However with this new dialled in rank I feel elated.
Jokers!!!!
on 04-04-2023 18:39
on 04-04-2023 18:40
on 04-04-2023 18:40
1.1.1.1 was dead last night/this morning for me and many others.
on 04-04-2023 18:41
on 04-04-2023 18:41
There certainly does not appear to be anything related to DNS in here...
04-04-2023 18:03:50 | warning | TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-04-2023 18:02:50 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-04-2023 18:02:50 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-04-2023 18:02:46 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
04-04-2023 18:02:45 | warning | TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-04-2023 18:02:45 | critical | No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-04-2023 18:02:35 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-04-2023 18:02:35 | warning | Dynamic Range Window violation |
04-04-2023 18:02:35 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-04-2023 18:02:35 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-04-2023 18:02:30 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-04-2023 18:02:26 | notice | TLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-04-2023 18:02:24 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-04-2023 18:02:22 | notice | Honoring MDD; IP provisioning mode = IPv4 |
04-04-2023 18:02:10 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-04-2023 18:02:08 | critical | TFTP failed - Request sent - No Response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-04-2023 18:02:08 | critical | TFTP Request Retries exceeded, CM unable to register |
04-04-2023 18:01:37 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-04-2023 18:01:34 | critical | DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-04-2023 18:01:30 | notice | Honoring MDD; IP provisioning mode = IPv4 |
04-04-2023 18:01:20 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-04-2023 18:01:03 | critical | Cable Modem Reboot via RG reboot command |
04-04-2023 16:53:46 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-04-2023 16:53:29 | critical | Cable Modem Reboot via RG reboot command |
28-03-2023 15:50:59 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 04-04-2023 18:43
on 04-04-2023 18:44
Echo similar comments, I don't think it's DNS server related. I've been using 8.8.8.8 and 1.1.1.1 for years as the router DHCP DNS servers and was affected by both outages today.
on 04-04-2023 18:44
How you getting that graphics data
