kan-izh
  • 19
Message 21 of 26
Re: Intermittent broadband for several months!
Still not fixed, just had another ~30 seconds gap. This is very disappointing experience. Could you please suspend the billing until the issue is fully resolved?
TimePriorityDescription
24-02-2023 21:56:05warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-02-2023 21:55:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-02-2023 21:55:52criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-02-2023 21:55:52critical16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-02-2023 21:51:37criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Robert_P
  • 5.52K
  • 251
  • 475
Message 22 of 26
We understand your frustration kan-izh, from checking your connection and equipment there does appear to be some power level issues on your downstream channels, with some errors on your upstream channel. Disconnections wise we can see one late on Friday around 9.50pm which is what you have referred to in your post but none since.
Have you noticed any improvement since that time?
Rob
kan-izh
  • 19
Message 23 of 26
Oh, thanks. It looks very promising so far. For about a week I have not experienced any issues.
Hopefully it's finally resolved for good, I'll keep an eye on it.
kan-izh
  • 19
Message 24 of 26
I think it's intermittent again. Noticed few interrupts today and I see two T3 timeouts...
kan-izh
  • 19
Message 25 of 26
Another glitch just now:
17-03-2023 09:54:53warningDynamic Range Window violation
17-03-2023 09:54:53warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-03-2023 09:54:18warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-03-2023 09:53:17errorDBC-ACK not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-03-2023 09:53:15warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-03-2023 09:53:15noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-03-2023 09:53:13warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Channel Frequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
04960000044.35120QAM 641
14310000045.35120QAM 642
23660000046.35120QAM 643
33010000047.35120QAM 644
42360000048.85120QAM 645
Martin_N
  • 8.87K
  • 371
  • 536
Message 26 of 26
Thank you for keeping us updated kan-izh.
I have taken a look on our side and it does indicate an engineer visit may help improve the issue.
I will private message you now to confirm your details.
^Martin
