agis_k
  • 22
Message 1 of 32
Intermittent broadband connection
I'm working from home full time and I am thinking of switching to another broadband provider, since I've called an engineer and apart from changing the cable, all the issues still remain.
My internet connection keeps dropping for 5-10 secs and then is coming back. For me working from home means that this behaviour is very disruptive and enough for kicking me out of a meeting or ruin a presentation.
Posting a message here, hoping that someone will actually investigate the problem is the last move before I switch to another provider.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 32
Re: Intermittent broadband connection
How are you connecting your device, Wi-Fi or ethernet cable ?
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
agis_k
  • 22
Message 3 of 32
Hi. Thank you for your quick reply.
I am connecting to the device through a Cat 6 ethernet cable. But when the connection is down, it affects everything.
I've already checked the cables from and to the Hub.
The service status is the first one I tend to check but it's green most of the times.
I'll paste the Router Status info, but I had to restart the router earlier today.
Agis
agis_k
  • 22
Message 4 of 32
1393999644.1512064 qam4
2462000144.2512064 qam3
agis_k
  • 22
Message 5 of 32
16990000001.438256 qam33
24910000002.738256 qam11
34990000002.438256 qam12
4507000000238256 qam13
5515000000238256 qam14
65230000002.438256 qam15
75310000002.538256 qam16
85390000002.438256 qam17
95470000002.538256 qam18
105550000002.238256 qam19
115630000002.238256 qam20
125710000001.238256 qam21
135790000001.738256 qam22
145870000001.738256 qam23
15595000000238256 qam24
16603000000238256 qam25
176110000001.738256 qam26
18619000000238256 qam27
196270000001.438256 qam28
206350000001.538256 qam29
216430000000.938256 qam30
226510000000.738256 qam31
236590000000.738256 qam32
247070000000.738256 qam34
1Locked38.6164269
2Locked38.93393230
3Locked38.92945285
4Locked38.92481237
5Locked38.62179241
6Locked38.61974227
7Locked38.91574211
8Locked38.61450245
9Locked38.61358219
10Locked38.61162274
11Locked38.61030225
12Locked38.9867196
13Locked38.6681228
14Locked38.9500217
15Locked38.6449218
16Locked38.9493318
17Locked38.9379215
18Locked38.9434224
19Locked38.6360273
20Locked38.6306209
21Locked38.6399225
22Locked38.6363234
23Locked38.6256264
24Locked38.6132217
agis_k
  • 22
Message 6 of 32
14/09/2020 11:05:13noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 10:18:43Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 09:29:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 09:19:52Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 09:10:36criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 08:48:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 02:03:51Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 01:45:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 00:23:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/09/2020 22:11:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/09/2020 19:19:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/09/2020 19:18:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/09/2020 19:18:49Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/09/2020 19:02:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/09/2020 15:45:1Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/09/2020 15:18:44criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/09/2020 15:16:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/09/2020 11:00:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/09/2020 09:49:1Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/09/2020 09:31:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
It's covering the mad addresses when I do copy paste. Please let me know if I can do it another way
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 7 of 32
The software is designed to 'rip' the MAC Address from the report.
agis_k
  • 22
Message 8 of 32
My BQM
bmeyer234
Message 9 of 32
I've got the same issues at E5 8AF.
Internet is jumping from 0.00mps all the way up to 100mbs
13310000001038256 qam25
22030000001038256 qam9
32110000009.938256 qam10
42190000009.938256 qam11
52270000009.838256 qam12
62350000009.838256 qam13
72430000009.838256 qam14
82510000009.538256 qam15
92590000009.138256 qam16
102670000008.438256 qam17
112750000008.538256 qam18
122830000008.638256 qam19
132910000009.338256 qam20
142990000009.838256 qam21
153070000009.838256 qam22
163150000001038256 qam23
173230000009.938256 qam24
1833900000010.338256 qam26
1934700000010.138256 qam27
203550000001038256 qam28
213630000001038256 qam29
2237100000010.138256 qam30
2337900000010.338256 qam31
2438700000010.438256 qam32
1462001024.3512032 qam3
2394001404.275512032 qam4
3326001854.25512032 qam5
4258000004.175512016 qam6
3ATDMA0000
4ATDMA0000
14/09/2020 13:31:49criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 13:31:49Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 13:30:27criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 13:30:26Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 13:30:26criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 13:29:5Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 13:29:5criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 13:29:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 13:29:4criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 13:27:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 13:27:42criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 13:26:19criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 13:26:19Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 13:26:4noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 13:24:57criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
In the process of pulling together a BQM graph. Will add once i've got it. This problem has been going on for 10 days now
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 10 of 32
... snip ...
If you want assistance please start your own thread.
