  • 10
Message 1 of 13
Intermittent and slow wifi
Hi, I pay for 200mbps broadband. However we don't get anywhere near this. In the last 6 months the very best I've had is 30 download and 3 upload. At worst it has been 0.87 down and 2 up. I'm extremely disappointed in this, it's been like this for a number of months now.
As well as the very slow speeds, the connection also drops out frequently, often multiple times a day, and usually at least once a day. This is very frustrating, especially as my husband and I are both working from home. We are unable to take part in key work meetings due to the connection dropping so much.
Please can someone help?
Tags (2)
  • 6.35K
  • 470
  • 834
Hero
Message 2 of 13
Re: Intermittent and slow wifi
How are you connecting your device, Wi-Fi or ethernet cable ?
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 10
Message 3 of 13
Hi Mike,
Thanks for the quick reply.
wifi, all devices
yes, no issues
Checked
i will do this now
  • 10
Message 4 of 13
  • 10
Message 5 of 13
Downstream
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1315000000-2.237256 qam23
2203000000-1.438256 qam9
3211000000-1.538256 qam10
4219000000-1.738256 qam11
5227000000-2.237256 qam12
6235000000-2.438256 qam13
7243000000-2.238256 qam14
8251000000-2.238256 qam15
9259000000-237256 qam16
10267000000-237256 qam17
11275000000-237256 qam18
12283000000-238256 qam19
13291000000-237256 qam20
14299000000-1.737256 qam21
15307000000-237256 qam22
16323000000-2.237256 qam24
17331000000-2.437256 qam25
18371000000-2.937256 qam26
19379000000-2.737256 qam27
20387000000-2.737256 qam28
21395000000-2.737256 qam29
22403000000-2.737256 qam30
23411000000-2.737256 qam31
24419000000-2.737256 qam32
1Locked37.6130
2Locked38.9200
3Locked38.650
4Locked38.61650
5Locked37.63901
6Locked38.6100
7Locked38.6180
8Locked38.680
9Locked37.670
10Locked37.6140
11Locked37.6110
12Locked38.680
13Locked37.6110
14Locked37.3120
15Locked37.6130
16Locked37.6250
17Locked37.3110
18Locked37.660
19Locked37.3130
20Locked37.3120
21Locked37.6120
22Locked37.680
23Locked37.6160
24Locked37.6110
  • 10
Message 6 of 13
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1394000004.125512064 qam9
2462000004.125512064 qam8
3537000004.225512064 qam7
4326000004.075512064 qam10
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
  • 10
Message 7 of 13
29/08/2020 14:17:43noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 07:00:53noticeNOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 01:25:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/08/2020 22:17:20Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/08/2020 22:17:20criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/08/2020 20:28:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/08/2020 20:27:47criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/08/2020 20:23:47Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/08/2020 20:23:47criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/08/2020 20:19:15criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/08/2020 20:19:14Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/08/2020 20:19:14criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/08/2020 20:19:1Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/08/2020 20:17:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/08/2020 20:17:32criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/08/2020 20:11:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/08/2020 20:11:16noticeNOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 6.35K
  • 470
  • 834
Hero
Message 8 of 13
Your Hub stats are looking OK to me.
Your >> BQM << needs time to get populated but from what little I can see there are line problems either an area problem or a problem between you and or at the street cabinet.
Just allow it to grow for a few more hours to get an accurate picture.
Mike Robinson
  • 10
Message 9 of 13
Thank you Mike. Hopefully in a few hours more stats will help you find the problem. Thanks, Bethan
  • 10
Message 10 of 13
Hi there, just wondering if there was enough data for this to be looked at now please? The Internet went off at approx 6:30pm today so I restarted the router if that's any helpful info.
