TempoVMStorm
  • 5
Intermittent Wifi, packet loss and Extremely High Latency
To put as briefly as possible:
M100 plan using the Hub3. Periods of extremely high packet loss. Pinging the router using command prompt or Powershell can get between 5 and 89% packet loss across all devices in the house.
The latency can spike up to 4000ms somehow, I expect it to be around 25ms to 8.8.8.8 and 2-5ms to my router, but averages at 300 due to the huge spikes.
Using the Wifi Analyzer app (the Virgin Media Connect app is complete trash), shows that my signal is hovering between -60 and -70 dBM, which shouldn't see that level of packet loss and latency from my understanding.
I've tried the usual, factory resetting Hub3 etc., even bought a powerful new wifi card to try out.
I only started the BQM after resetting, so the BQM hasn't been going for too long yet. But looking at it so far, it seems like it's all on my side (hopefully the link below works).
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/f775da8534299e322acd61ead57c498895761e98]My Broadband Ping[/url]
TempoVMStorm
  • 5
Re: Intermittent Wifi, packet loss and Extremely High Latency
Cable Modem Status Item Status Comments
419000000
Locked
Ranged Upstream Channel (Hz)
60300000
Locked
Provisioning State
Online
1419000000-2.738256 qam32
2203000000038256 qam9
3211000000-0.738256 qam10
4219000000-0.738256 qam11
5227000000-0.938256 qam12
6235000000-0.938256 qam13
7243000000-1.538256 qam14
8251000000-238256 qam15
9259000000-2.938256 qam16
10267000000-3.738256 qam17
11275000000-338256 qam18
12283000000-2.238256 qam19
13291000000-1.938256 qam20
14299000000-1.238256 qam21
15307000000-0.738256 qam22
16315000000-0.938256 qam23
17323000000-138256 qam24
18363000000-0.738256 qam25
19371000000-0.540256 qam26
20379000000-0.938256 qam27
21387000000-1.938256 qam28
22395000000-2.538256 qam29
23403000000-2.738256 qam30
24411000000-2.438256 qam31
1Locked38.9580
2Locked38.9340
3Locked38.6340
4Locked38.6110
5Locked38.9100
6Locked38.9220
7Locked38.6110
8Locked38.6110
9Locked38.6260
10Locked38.6330
11Locked38.6180
12Locked38.6330
13Locked38.6170
14Locked38.990
15Locked38.6290
16Locked38.9110
17Locked38.6120
18Locked38.950
19Locked40.3220
20Locked38.9390
21Locked38.9410
22Locked38.6631
23Locked38.6691
24Locked38.9540
16030000044.5512064 qam1
23940000043.8512064 qam4
34620000044.3512064 qam3
45370000044.5512064 qam2
3ATDMA0000
4ATDMA0000
TempoVMStorm
  • 5
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID496602
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID496601
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
19/01/2021 16:14:26noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2021 10:31:19noticeSW download Successful - Via Config file
19/01/2021 10:29:17Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2021 10:29:7noticeSW Download INIT - Via Config file
18/01/2021 21:18:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/01/2021 01:21:52ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/01/2021 02:37:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 14:25:27noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 23:46:50ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 00:38:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 13:56:53ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 18:27:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 14:54:12noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 04:07:39noticeSW download Successful - Via NMS
08/01/2021 04:05:53noticeSW Download INIT - Via NMS
07/01/2021 11:20:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/01/2021 23:43:45ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2021 12:05:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 21:35:22ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
TempoVMStorm
  • 5
Re: Intermittent Wifi, packet loss and Extremely High Latency spikes
I'm assuming I didn't get a response because of how late i posted this, so i'm just going to bump this and repost my BQM. I don't know how to post it directly into the post like how the others do it though.
gary_dexter
  • 28.87K
  • 1.76K
  • 3.77K
Bumping is against forum rules.
A forum rep will respond in 5-10 days time.
TempoVMStorm
  • 5
Ah I see. I didn't see that as part of the house rules, so thanks for clearing that up for me. I guess I'll just wait for a response then.
