Rederniy
  • 13
Message 1 of 17
Intermittent Wifi issues
Hi all,
To clarify I own the account, but not at the premises, however I spend some time diagnosing yesterday. Therefore I will not be able to get any logs from the device.
Issue:
intermittently all devices lose wi-fi connectivity. At the same time the SSID of the Hub 3 goes missing. Service checks show the hub is online and light on Huib3 is white. During the outages the Tivo Box (connected by ethernet) does not show any connection errors.
Usually after about 10 minutes this settles the wifi comes wifi back.
I checked the logs and around the same time of the issues there are T3 Timeout issues being entered.
Checks/Actions taken:
Restarted Hub  - Issue reoccurred
Reset Hub - stable for 15 hours then back to intermittent until earlier
Current issue:
Wifi fails, Hub 3 light orange and the misses restarted. Wifi came back but failed about an hour later.
Service status - No issues in our area and the online hub checker comes back green.
Any ideas would be gratefully received
Thank you all
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 17
Re: Intermittent Wifi issues
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Rederniy
  • 13
Message 3 of 17
Thank you for your response. I have ran BQM for the last 2 hours and this is the result so far.
As I said in my post I am not at the location, however I will be using Zoom later to screen share that location, from which I will gather the logs requested from the router itself. Once completed I will share them with an updated BQM graph.
I am also include a comparison with my internet: (both locations are on 100MB, Linds has the white Hub3, me the Black one)
Kind Regards
Rederniy
  • 13
Message 4 of 17
First Ignore the bottom graph, I power down when out hence the constant timeouts
Update 1 of 3
As requested:
147500000010.140256 qam33
22190000008.640256 qam11
32270000008.540256 qam12
42350000008.340256 qam13
52430000007.840256 qam14
62510000007.840256 qam15
72590000008.138256 qam16
82670000008.540256 qam17
92750000008.640256 qam18
10283000000940256 qam19
11291000000940256 qam20
122990000009.640256 qam21
133070000009.940256 qam22
1431500000010.140256 qam23
1532300000010.540256 qam24
1641100000010.540256 qam25
1741900000010.540256 qam26
1842700000010.440256 qam27
1943500000010.440256 qam28
2044300000010.440256 qam29
2145100000010.440256 qam30
2245900000010.440256 qam31
2346700000010.340256 qam32
2448300000010.440256 qam34
Rederniy
  • 13
Message 5 of 17
Update 2 of 3
1Locked40.9440
2Locked40.9500
3Locked40.3590
4Locked40.3670
5Locked40.31110
6Locked40.9860
7Locked38.91890
8Locked40.31080
9Locked40.9930
10Locked40.9750
11Locked40.3490
12Locked40.3640
13Locked40.3650
14Locked40.3740
15Locked40.3580
16Locked40.921880
17Locked40.932410
18Locked40.324050
19Locked40.918040
20Locked40.9590
21Locked40.9500
22Locked40.9630
23Locked40.9500
24Locked40.3700
Rederniy
  • 13
Message 6 of 17
Update 3 of 3
1394001063.975512064 qam2
2257999693.925512064 qam4
3461999904512064 qam1
4326001223.975512064 qam3
3ATDMA0000
4ATDMA0000
03/10/2020 03:14:8ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 00:16:39ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 23:41:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 03:34:43ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/09/2020 16:15:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 15:43:28noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 15:43:22Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 15:42:45noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 15:29:34Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 15:13:0Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 15:12:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/09/2020 18:50:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/09/2020 19:14:17ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/09/2020 15:00:11ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/09/2020 08:23:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/09/2020 07:28:43ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 09:44:43ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2020 02:03:36ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/09/2020 20:53:45ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 7 of 17
Your Downstream Power Levels are too high on several channels.
You will need an engineer to put them back into spec.
Rederniy
  • 13
Message 8 of 17
Thank you very much.
Anyone know the best way of getting an engineer engaged, as the phone service passes me to this community site?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 9 of 17
You can either phone in (08:00 is the best time) or wait on here for a few days until one of the VM Forum Staff comes along.
Rederniy
  • 13
Message 10 of 17
Rang and got through to VM this morning.
They checked, diagnosed a weak signal, found some issues with the hub and are sending a new hub out.
On the positive side the colour will match the tivo box so the misses will be happy, sadly though I am not sure a new hub will sort this, but only time will tell (and would love to be proved wrong 🙂 ).
Nevertheless thank you @mikeRobbo for your time and diagnosis, it really was appreciated.
