hannahknight0
Intermittent WiFi
My wifi has been dropping in and out for weeks now. It's become really disruptive with work and I have tried to fully reset the modem and contacted virgin media multiple times to no avail.
If anyone has any ideas or tips I would be really grateful.
It looks like my Pre RS errors are pretty big...
1Locked38.91805217729
2Locked36.66437728755
3Locked36.619289020358
4Locked36.3953482252935
5Locked35.45536502306707
6Locked37.619841713681
7Locked37.35570915854
8Locked37.65474717037
9Locked37.32234617654
10Locked37.62544120701
11Locked37.62578122741
12Locked38.62576327485
13Locked38.618767031121
14Locked38.611095528562
15Locked38.61080025372
16Locked38.6846122119
17Locked38.6846022491
18Locked38.9865419242
19Locked38.9908818572
20Locked38.9934217683
21Locked38.61062317597
22Locked38.91309116955
Tags (1)
tehwolf
  • 1.56K
  • 253
  • 379
Superfast
Re: Intermittent WiFi
you need post a full set of logs (upstream, downstream and network log tabs).
hannahknight0
387000000
Locked
Ranged Upstream Channel (Hz)
39399825
Locked
Provisioning State
Online
13870000005.838256 qam32
2203000000136256 qam9
32110000001.236256 qam10
42190000001.536256 qam11
52270000001.735256 qam12
62350000001.537256 qam13
72430000001.937256 qam14
82510000002.437256 qam15
92590000002.237256 qam16
102670000002.537256 qam17
11275000000337256 qam18
122830000003.238256 qam19
132910000003.238256 qam20
14299000000438256 qam21
153070000003.938256 qam22
163150000004.138256 qam23
13939982551512032 qam4
26029981551512064 qam1
34619991651512064 qam3
45370017651512064 qam2
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID48062
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID48061
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Network LogTime Priority Description
23/02/2021 13:53:52Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/02/2021 13:53:51Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/02/2021 13:49:52Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/02/2021 13:49:51Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/02/2021 13:49:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0
hannahknight0
Thank you so much - replied with more details!
  • 2.5K
  • 177
  • 511
Problem sorter
PostRS errors are horrendous.  Looks like noise ingress and will need an engineer to sort out.  In the meantime, reboot the Hub and keep an eye on the PostRS errors. If they rise quickly, it's a definite problem.  You can also check all the co-ax connections are tight, as loose ones can cause noise on the circuit.
tehwolf
  • 1.56K
  • 253
  • 379
Superfast
power on upstream is high - i believe 50 is the recommended max (someone else may be able to confirm...), and you're above that on all four channels.
post-rs errors are really high and. per previous comment, would imply some sort of noise on the line..
You can either call this in and hope that the call handler agrees that there's an issue, or you can wait around here for a few days for a forum staffer to comment - they can arrange an engineer for you if it's needed.. if you're going to do the latter, it would also be worth setting up a BQM - once set up, find the Live Graph and click "Create Sharing Link" - post that back here. It'll be one less thing to do when VM get to the post.. and the data will already be there.
