  • 6
Message 1 of 5
Intermittent WiFi
I’ve noticed recently that the WiFi drops off more and more regularly. This can happen a couple of times an hour, all devices connected via WiFi loose connection and the green WiFi light on the router flashes. All wired connections seem fine.
getting answers is becoming frustrating
  • 12.14K
  • 943
  • 1.56K
Message 2 of 5
Re: Intermittent WiFi
It may be a good idea to carry out a factory reset on the Hub …
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Instructions for Hub 3
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once a steady white and no other lights are illuminated check your system again.
Mike Robinson
  • 6
Message 3 of 5
I’ve reset the hub when this all started but it still does the same.
  • 12.14K
  • 943
  • 1.56K
Message 4 of 5
You can try VM to see if they will replace the Hub.
In the mean time ...
Then
Can you please
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
Mike Robinson
  • 1.91K
  • 74
  • 138
Message 5 of 5
Hi deanininio,
Thank you for getting in touch.
We apologise for the delay in response and for the issue you are experiencing with the WiFi.
I have taken a look from our side and an confirm there are no area issues that would be causing this.
I have also looked at the specs for the equipment and they are all in the green.
Can you please let us know if you are still experiencing this issue?
Nat
