  • 5
Message 1 of 5
Intermittent WiFi
For several weeks the WiFi keeps completely dropping out for anything from minutes to hours everyday.
We have rebooted and reset the hub so many times, checked service status and there are no problems. The only light on is the yellow one at the bottom. Previously there were always other ones - a green WiFi symbol I think.
I have phoned up and had no help except to follow online advice (again). I’ve complained on Twitter and been told to text the tech team, which I did but that is only a bot who doesn’t reply.
What can I do to get an engineer out..or even speak to an actual person?! Needless to do I am very fed up!!
  • 25.12K
  • 1.44K
  • 3.2K
Message 2 of 5
Re: Intermittent WiFi
Do wired connections also drop?
  • 14.81K
  • 622
  • 1.43K
Message 3 of 5
VM router mode with wifi was a bad idea but they seen to like trying and failing so if you want something done about it get your own wireless router with 1Gb ports and use the hub in modem mode.
  • 5
Message 4 of 5
There is only one wired connection, that is my teenage son uses for PS4, he is vague but says it does still stop working. Think he gets confused between slowness/lagging and just not working!
  • 1.9K
  • 97
  • 177
Message 5 of 5
Hi Beckyflipflop, thanks for posting and welcome to our community.
I am sorry to hear you're having issues with your connection.  I would like to take a closer look. To enable me to do so, I am going to send you a private message.  Please look out for the purple envelope in the top right of your screen.
Lee_R
