Dannig23
Message 1 of 5
Intermittent WiFi with 2.4GHz completely missing
Exactly what the title says. No 2.4GHz available anymore on my router. With the WiFi constantly dropping out. I have the hub 3. Already checked all connections and turned the router off and on and reset the router
  • 32.27K
  • 3.17K
  • 6.12K
Message 2 of 5
Re: Intermittent WiFi with 2.4GHz completely missing
There are lots of reports similar to this where a firmware bug in the Hub3 causes one of the wifi channels to either switch off or change its name (sometimes to "1").
Go into the Hub settings and see if that has happenend.
Dannig23
Message 3 of 5
I’ve done the 192.168.0.1 got the webpage but it keeps telling me the password is wrong even though I’m using the settings password on the bottom of the router
  • 32.27K
  • 3.17K
  • 6.12K
Message 4 of 5
You will have to do a pinhole reset as below in order to get it back to factory settings.
__________________
Note that a pinhole reset on a Hub3/4 can be a bit problematic - so do it (again) EXACTLY this way (not as the VM website says!).
With the Hub still switched "on", disconnect any ethernet connections (leave the co-ax connected) and then push in the “reset pin” with the end of a paperclip/thin nail/SIM tray “tool” or similar (bigger items like ball point pen ends may not press it in far enough) until you feel it at the “stop point” and hold it there firmly for a "timed" minimum of 60 seconds do NOT manually restart the Hub at any time.
Leave it 10' or so to re-initialise and then your passwords/passphrase for both the Hub settings and the Wifi networks will revert to the two printed on the Hub sticker on its base/side/card. Make sure you use the wifi one for devices connecting to the wifi and the settings/admin one to access the Hub
See if that sorts it.
Zach_R
  • 3.79K
  • 125
  • 269
Message 5 of 5
Hi @Dannig23,
Thank you for your posts and welcome to our community forums. We're here to help.
I am very sorry to hear that you've been having some problems with your Wi-Fi service recently. Are these ongoing today? If so, have you followed the advice provided by @jbrennand to see if that helps at all?
Zach - Forum Team
