Intermittent WiFi still
We have been having issues for weeks,carnt get through when I try to call just an automated message to say there’s a complexed problem,then finally got through on the app,to be told it would be fixed by the 15th Oct by 4pm and still having issues,cut off 5 times in 20 minutes whilst trying to watch a program,so once again on the app to speak to a robot to get put through to an agent that takes 24 hours and if you don’t respond straight away it puts u back to the robot again!it’s so annoying and still paying full price!!£42 a month for broadband that’s not working!!
  • 12.15K
  • 943
  • 1.56K
Re: Intermittent WiFi still
Then
Can you please
Mike Robinson
I have absolutely no idea how to even go about doing that,I’m sorry,I’ll look into it though and see what I can do?
