  • 9
Message 1 of 16
Intermittent Wi-Fi at times.
Hi all,
Been with virgin a few years but just thought I'd make an account. We upgraded last month to a new contract (500mb Oomph bundle).
When it comes to the internet, I've been having issues. It was okay before the upgrade to be fair, but after, it can sometimes just have issues, very short I may say.
I have had devices disconnect from the internet and reconnect, I've had devices say they're connected but not actually load any webpage or anything, and when using my PC for gaming on Wi-Fi, I have had packet loss nearly every day. Again, none of this happened before.
Not sure if this has anything to do with the fact we had a splitter due to the 2nd V6 box that came with the contract? I did try tighten all the connections up but still didn't help.
Thank you
Ji
  • 11.99K
  • 934
  • 1.53K
Message 2 of 16
Re: Intermittent Wi-Fi at times.
The problem with Wi-Fi is that it can be brilliant at breakfast time and useless by lunchtime and you haven't changed anything, BUT, something, somewhere has changed, then you can spend hours and even days trying to find a fix for something that can be totally out of your control.
If you remove all the internal walls, water, electronic and electrical devices, metallic pipes and conduits and wrap the whole building in a thick lead shield you will have a good chance of getting decent Wi-Fi from an ISP Hub.
Just a few things that can affect Wi-Fi in the average home …
Mirrors, furniture, fish tanks, people, radiators, walls (some more than others), flooring / ceilings, cordless phones, baby monitors, microwave ovens, fridges & freezers, TVs, next doors Wi-Fi and Wi-Fi equipment, DAB transmitters, the list is endless.
Many people have accepted that the VM Wi-Fi is poor and have purchased third party equipment that is much, much more powerful than the VM supplied kit and once set up have wondered why they waited for so long.
Mike Robinson
  • 3.65K
  • 285
  • 514
Superfast
Message 3 of 16
@JiSingh1 wrote:
Hi all,
Thank you
Ji
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode . You shouldn't need log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs? Please copy/paste this data as text, split between multiple posts (Sometimes you have to click 'Post' twice due to an error message).
Could you please create a BQM (Broadband Quality Monitor) here, and post the live link?
  • 9
Message 4 of 16
Sure.
12030000004.638256 qam9
22110000004.838256 qam10
32190000004.838256 qam11
42270000004.638256 qam12
52350000004.538256 qam13
62430000004.538256 qam14
72510000004.438256 qam15
82590000004.138256 qam16
92670000004.138256 qam17
102750000004.538256 qam18
112830000004.838256 qam19
12291000000538256 qam20
132990000005.538256 qam21
143070000005.538256 qam22
153150000005.438256 qam23
163230000005.538256 qam24
173630000005.838256 qam25
183710000005.538256 qam26
193790000005.438256 qam27
203870000004.838256 qam28
213950000004.938256 qam29
224030000005.138256 qam30
23411000000538256 qam31
244190000004.838256 qam32
1Locked38.62430
2Locked38.64320
3Locked38.92190
4Locked38.62450
5Locked38.65280
6Locked38.63300
7Locked38.63820
8Locked38.63530
9Locked38.65750
10Locked38.63270
11Locked38.63520
12Locked38.62690
13Locked38.62630
14Locked38.92960
15Locked38.63070
16Locked38.62180
17Locked38.63600
18Locked38.61830
19Locked38.92210
20Locked38.92510
21Locked38.63150
22Locked38.92500
23Locked38.64780
24Locked38.62430
  • 9
Message 5 of 16
16030000046.5512064 qam1
23939994145512064 qam4
35370000046512064 qam2
44620000045.5512064 qam3
1ATDMA0010
2ATDMA0050
3ATDMA0020
4ATDMA0010
  • 9
Message 6 of 16
23/11/2020 21:09:28noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/11/2020 21:09:14Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 17:48:46ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 03:37:52noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 15:28:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 21:32:25noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 16:48:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 05:48:45ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/11/2020 01:33:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/11/2020 00:20:5noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 17:48:45ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 12:53:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 08:55:39ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 04:01:30noticeSW download Successful - Via NMS
09/11/2020 03:59:41noticeSW Download INIT - Via NMS
01/01/1970 00:01:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 00:04:56noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 13:41:51ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 15:57:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
To be fair, everything looks ok to me, but the packet loss and disconnect is only for a few seconds at random times so i doubted anything would show up.
  • 11.99K
  • 934
  • 1.53K
Message 7 of 16
Mike Robinson
  • 9
Message 8 of 16
Hopefully Done it correct.
Do I have to leave the web page open and also leave my PC on? That's the device I've used although the intermittent WiFi happens on all devices.
My BQM
  • 9
Message 9 of 16
Everything looks ok on the B, which is annoying, but my PC disconnected earlier on completely and my mother said that the iPad stopped playing videos and ended up buffering for about 15 seconds.
Weird.
  • 11.99K
  • 934
  • 1.53K
Message 10 of 16
Yes it is monitoring OK.
No as long as the Hub is switched on the BQM will record, everthing else can be switched off / closed.
Mike Robinson
