jproblem123
Message 1 of 7
Intermittent/Unstable Broadband affected by outside
Hello,
I am experiencing extreme intermittent broadband service which constantly cuts out. I have noticed this happens frequently when trains go past or when there is bad weather.  I never had these issues with BT or SKY only with Virgin since I joined in July.  My hub light has been yellow since i got it (never the white that its supposed to be).  I believe there are issues with the line, but the poor customer service i am receiving from a computer system is saying i do not have any issues and so i am being refused an engineer visit.  There must be some issues externally, loose connections to be affected by trains going past and having my connection disconnected or to have wifi but no internet.
The wifi was installed using an old Telewest cable we had in the flat, this had not been used for well over a decade.  The cable was cut and a short extension added to connect to the hub.  The new cable is maybe a meter long, compared to the old telewest cable that runs approx 15 metres through the flat.
Think Broadband shows varying results including packet loss (hope the links work below).  The only time i disconnected the broadband was 13/04
Today: 14/04
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/991a4f515192a4d4462ec8d67aafeea7f6830ff7-14-04-2021][img]https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/991a4f515192a4d4462ec8d67aafeea7f6830ff7-14-04-2021.png[/img][/url]
13/04
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/aba66c808a6e09f24fce602dbab9793618b09e01-13-04-2021][img]https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/aba66c808a6e09f24fce602dbab9793618b09e01-13-04-2021.png[/img][/url]
12/04
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/9af10dc29d3e8aa483b1b02e19aa315bfcc89d4a-12-04-2021][img]https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/9af10dc29d3e8aa483b1b02e19aa315bfcc89d4a-12-04-2021.png[/img][/url]
11/04
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/f69ee4850c71a4624bbfd1149a80468de0c4da4b-11-04-2021][img]https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/f69ee4850c71a4624bbfd1149a80468de0c4da4b-11-04-2021.png[/img][/url]
10/04
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/7e1dfb2ba1696d2d9f3a2b9ff8d666fdcf85bdc2-10-04-2021][img]https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/7e1dfb2ba1696d2d9f3a2b9ff8d666fdcf85bdc2-10-04-2021.png[/img][/url]
 09/04
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/41b66080c8b52fcbf6b8d2051d5410e32a8a9588-09-04-2021][img]https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/41b66080c8b52fcbf6b8d2051d5410e32a8a9588-09-04-2021.png[/img][/url]
 05/04
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/3fc8af2c1fb63dded94345f192ffe6a863a4d69d-05-04-2021][img]https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/3fc8af2c1fb63dded94345f192ffe6a863a4d69d-05-04-2021.png[/img][/url]
Can any one help to identify the issues and hopefully get an engineer to check my connections?
Thanks in advance
Jade
lotharmat
  • 937
  • 70
  • 141
Well-informed
Message 2 of 7
Re: Intermittent/Unstable Broadband affected by outside
Can you post your Hub status and logs?
Someone should be spot if there is a problem
Navigate to http://192.168.0.1 (or http://192.168.100.1 - if in modem mode)
Don't log in!
Click on 'router status'
Copy/paste the data from each of the tabs. The forum software will remove the MAC addresses for you (you may need to click the 'post' button again).
jproblem123
Message 3 of 7
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
203000000
6.4
38
256 qam
9
2
211000000
6.5
38
256 qam
10
3
219000000
6.5
38
256 qam
11
4
227000000
6.5
38
256 qam
12
5
235000000
6.5
38
256 qam
13
6
243000000
6.6
38
256 qam
14
7
251000000
7
38
256 qam
15
8
259000000
7
38
256 qam
16
9
267000000
7
38
256 qam
17
10
275000000
6.9
38
256 qam
18
11
283000000
7.5
38
256 qam
19
12
291000000
8
38
256 qam
20
13
299000000
8.6
38
256 qam
21
14
307000000
8.6
38
256 qam
22
15
315000000
8.6
38
256 qam
23
16
323000000
8.5
38
256 qam
24
17
331000000
8.6
40
256 qam
25
18
339000000
9.1
38
256 qam
26
19
347000000
9.4
38
256 qam
27
20
355000000
9.4
40
256 qam
28
21
363000000
9.4
40
256 qam
29
22
371000000
9
40
256 qam
30
23
379000000
8.9
38
256 qam
31
24
387000000
9
40
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.6
19
0
2
Locked
38.9
45
0
3
Locked
38.6
14
0
4
Locked
38.6
21
0
5
Locked
38.9
29
0
6
Locked
38.9
23
0
7
Locked
38.6
17
0
8
Locked
38.6
25
0
9
Locked
38.9
14
0
10
Locked
38.6
27
0
11
Locked
38.9
20
0
12
Locked
38.9
12
0
13
Locked
38.9
13
0
14
Locked
38.9
18
0
15
Locked
38.9
14
0
16
Locked
38.6
10
0
17
Locked
40.3
18
0
18
Locked
38.9
23
0
19
Locked
38.9
25
0
20
Locked
40.3
30
0
21
Locked
40.3
31
0
22
Locked
40.9
14
0
23
Locked
38.6
11
0
24
Locked
40.3
0
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
43.3
5120
64 qam
11
2
46200000
43
5120
64 qam
7
3
39400000
43
5120
64 qam
8
4
25800220
43
5120
64 qam
12
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
14/04/2021 13:30:53noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/04/2021 20:30:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/04/2021 16:04:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2021 20:01:48noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2021 20:01:18Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2021 19:03:3ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/04/2021 05:07:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/04/2021 05:07:1criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/04/2021 05:03:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/04/2021 05:02:33criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/04/2021 05:00:32Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/04/2021 05:00:28Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/04/2021 05:00:28criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/04/2021 08:57:12ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2021 04:57:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/03/2021 08:57:12ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/03/2021 10:48:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/03/2021 09:45:34ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
jproblem123
Message 4 of 7
Ok think i figured this out, hope this is of some use
Today
My Broadband Ping - 1202
13.04
12.04
11.04 same as 10.04
09.04
Tags (1)
Robert_P
  • 2.57K
  • 129
  • 216
Message 5 of 7
Hello jrproblem123
Really sorry to hear of the broadbadn issues experienced, we appreciate you raising this via the forums and welcome to the community.
We've taken a look at your equipment and connection and everything appears to be within the spec's and ranges we'd expect. From looking at the wireless network there does appear to be some issues with certain devices, namely two iPads and a set top box. From the information we have here it would appear these devices are out of range.
We have these tips available to help with broadband issues:
Rob
jproblem123
Message 6 of 7
Hi Rob,
I would rather you look at the issues i have posted as your system does not seem to pick up the issues i am having.  You will see there are issues on the graphs i displayed, are you able to explain the dropped packets?  I have already had your team explain that your computer system says i am not having any issues however my the human using it is confiming i am - and this is with all devices!
J
Robert_P
  • 2.57K
  • 129
  • 216
Message 7 of 7
We appreciate the frustration, can you perform a pin hole reset on the hub and let the BQM run for a period of 24 hours and post the results here.
This is due to other BQM's at the same time for other customers showing the same result.
Rob
