I'm having an intermittent network issue over the last few days, with all devices losing connection frequently (both wired and wifi).
Service checker (when it manages to run without timing out) reports no issues in my area. I have tried all the troubleshooting steps in my home.
When running a speedtest, my download speed is extremely limited, and my upload speed is zero. Most of the time, the test doesn't load at all. https://www.broadbandspeedchecker.co.uk/test-result.html?id=374517442
The issue is almost exactly as I described only a few short months ago in this thread (an issue which was believed to be resolved): https://community.virginmedia.com/t5/Networking-and-WiFi/Intermittent-Network-Issue/m-p/4445560#M332...
Assuming that the cause of the issue is the same as it was back in October, whatever fixed that previous issue was only temporary and a more permanent solution is needed.
Similarly to the previous issue, I checked the router status again only 2 upstream channels (power level too high), many errors in the network log including critical errors, partial service errors etc. I will post these separately.
Please can someone at VM help me with this issue? This needs to be resolved as my connection is proving to be consistently unreliable.
