m1ms88
Intermittent Jitters, buffering and dropouts please help
Good Evening
So for the past 3 - 4 weeks i have been experiencing jitters, buffering and dropouts, and whilst i run speed test and it reports back the correct download and upload spee.
I experience these issues especially when Gaming(Jitters / Rubber-banding), Streaming Media (buffering) and rare but complete dropouts. these do tend to occur during busy periods which has lead me to believe the it’s just the local VM node being overwhelmed.
i have currently done the following troubleshooting, I have changed coaxial cable, replaced all RJ45 network cables, rebooted the super hub and reset to factory defaults.
I have also ran the hub in modem mode and tested whilst only connected only to 1 pc.
The last test I have done is run modem in modem mode and use an additional router which helped a little.
Kind Regards
Simon (M1Ms88)
tehwolf
  • 1.57K
  • 253
  • 379
Superfast
Re: Intermittent Jitters, buffering and dropouts please help
 hopefully, the coax you used as a replacement was provided by VM - 3rd party coax isn't supported by VM and can introduce noise into the network and impact not just you but other people in your area..
anyways, it sounds like you've done a decent set of tests.. so next steps are to:
set up a BQM to see how your connection looks from the outside..
post your router stats - browse to http://192.168.0.1 - don't log in, click Router Status. Copy/paste the information from Upstream, Downstream and Network Log back to this thread, you'll need to split it across multiple posts as it won't all fit into one..
m1ms88
The Coax was provided by VM when we upgraded I was given a new modem Super Hub 3 and new coax which I didn’t use at the time.
please find attached my downstream, upstream and network log
I will install the monitor later on this evening if possible
tehwolf
  • 1.57K
  • 253
  • 379
Superfast
it's easier to use copy/paste rather than screenshots as a) it will capture all of the data (there's only half a page of the downstream in your screenshot) and b) it will remove any information that you're not supposed to post from the network log (e.g. MAC address..)
