  • 10
Message 1 of 5
Intermittent Ethernet connection on super hub 2
Hi Virgin support,
I've been going in circles, trying to call, resetting the hub - no luck
I work from home and my ethernet connection is dropping throughout my work day which is a real problem - Im trying to order a new hub, since resetting the old one doesn't work (im at it for almost two weeks, pressing the reset button at the back many times) - Wifi is disconnecting as well throughout the day - I've tried to order a hub 4 but with no success - Can you help please?
  • 24.77K
  • 1.43K
  • 3.15K
Message 2 of 5
Re: Intermittent Ethernet connection on super hub 2
Do the lights on the hub change when the connection drops?
  • 17.45K
  • 1.83K
  • 3.04K
Message 3 of 5
As Mike says - are you sure its isn't a network connection issue? Have you called in to report the fault and see what they say when they look at your connection?
Re. a "new" Hub - did you try the "free" SH1/2/2ac upgrade/replacement scheme - see the link below?
You are likely to get a Hub3 - Hub4's are for GB customers only - or by invitation from VM in areas that are enabled to use docsis3.1
If you tried the link and got Oopsed, it usually means you are on an old package that the computer cant recognise so they want to speak to you about it. When you call it in it's a coin toss whether the agent knows about the scheme. If they do they will just say "ok we will send one out" - or - they say "oh no, that's an upgrade there will be a charge and it starts a new contract". Neither of those statements in correct - so just say no thanks and leave the call.
After that you could try texting on 07533 051809 - include account name/number and what the issue is and see what they say – replies may take a bit longer
Finally a VM person should pick this up here and sort the swap for you, but it can take several days.
https://www.virginmedia.com/shop/hub-swap.html?buspart=uk_app_connect2_hubswap
  • 10
Message 4 of 5
Thank you - im not sure I'll have a look next time it does happen -
  • 10
Message 5 of 5
Thank you for your reply - really appreciated the answer and the tips - I have called but since waiting time was very long I didn't go through with the call -
