zainul
Message 1 of 5
Intermittent Connection
For the past week, I have been having an intermittent connection. I have contacted VM many times and they have found no solutions to my problem.
Here are the errors I have found in the network logs:
01/05/2021 12:41:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2021 11:48:19Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 23:01:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 22:26:46Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 15:39:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2021 13:49:26noticeNOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/04/2021 14:19:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/04/2021 14:18:15Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/04/2021 13:05:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/04/2021 12:09:21Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/04/2021 12:02:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/04/2021 08:40:14Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 13:56:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 10:44:59Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/04/2021 17:44:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/04/2021 17:33:34Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/04/2021 16:43:58noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/04/2021 16:43:49Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/04/2021 16:43:10noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/04/2021 16:42:27Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1ATDMA0030
2ATDMA0050
3ATDMA0010
4ATDMA0010
Is there anything that can be done to resolve this? I have suggested to the support team that I need an engineer to fix the issue, but they seem very hesitant in sending one.
lotharmat
  • 937
  • 70
  • 142
Well-informed
Message 2 of 5
Re: Intermittent Connection
Post up the rest of your hub stats! - Someone should be able to spot something!
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc - You can do this at ThinkBroadband (https://www.thinkbroadband.com/broadband/monitoring/quality)
zainul
Message 3 of 5
here are the rest of the stats:
133100000011.538256 qam25
220300000010.438256 qam9
321100000010.438256 qam10
421900000010.440256 qam11
52270000009.838256 qam12
62350000009.338256 qam13
72430000009.338256 qam14
82510000009.938256 qam15
92590000001038256 qam16
1026700000010.438256 qam17
1127500000010.638256 qam18
1228300000011.140256 qam19
1329100000011.338256 qam20
1429900000011.538256 qam21
1530700000011.540256 qam22
1631500000011.840256 qam23
1732300000011.540256 qam24
183390000001238256 qam26
193470000001240256 qam27
2035500000011.940256 qam28
2136300000011.640256 qam29
2237100000011.940256 qam30
2337900000011.938256 qam31
2438700000011.640256 qam32
1Locked38.9320
2Locked38.9230
3Locked38.9160
4Locked40.3160
5Locked38.9270
6Locked38.9280
7Locked38.9540
8Locked38.9280
9Locked38.9600
10Locked38.9470
11Locked38.9430
12Locked40.3360
13Locked38.9340
14Locked38.9360
15Locked40.3160
16Locked40.3260
17Locked40.3340
18Locked38.9400
19Locked40.3410
20Locked40.9340
21Locked40.3380
22Locked40.3170
23Locked38.9210
24Locked 40.99
0
14620000049512064 qam1
23939993149512064 qam2
32580000048.3512032 qam4
43260000048.8512064 qam3
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
lotharmat
  • 937
  • 70
  • 142
Well-informed
Message 4 of 5
Downstream power is too high! That'll require an engineer visit!
Martin_N
  • 5.3K
  • 224
  • 302
Message 5 of 5
Hi zainul,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the issue you're having with your broadband.
I have been able to locate your account and have ran an initial check and nothing is showing as causing a fault.
What I need to do is private message so we can confirm some data protection and proceed through some checks.
^Martin
