Intermittent Connection
Hi Guys,
I'm using the hub 3 in modem mode and it's been working fine for around a year and now suddenly it keeps losing internet connection all the time, sometimes for 30 seconds, sometimes for 10 minutes.
The internal network stays up so I know it's an issue with my virgin connection/hub.
Looking at the network log I'm seeing a lot of the below errors.
No Ranging Response received - T3 time-out
Unicast Ranging Received Abort Response
RCS Partial Service;CM
SYNC Timing Synchronization failure - Loss of Sync
Is there anything I can do to fix this or does it need an engineer to visit?
  • 3.65K
  • 283
  • 513
Superfast
Re: Intermittent Connection
@Jollies wrote:
Hi Guys,
It sounds like you have an intermittent issue with your line.
You need to contact VM as it could be a local area issue being worked on, in which case they wouldn't send an engineer.
Try the text service 07533051809.
Hi Carl,
Thanks for replying, this has been going on for a few weeks and nothing has been reported in my local area, on their service checker everything is OK
  • 3.62K
  • 215
  • 277
Hi Jollies,
Thanks for posting and welcome to our community 🙂
Sorry to hear you're having some issues with your hub, I've been able to locate the account using your forum details and can see a couple of the hubs downstream channels are out of specification.
I can see it's been over a week since the hub was last rebooted, can you please do this and I'll check the levels again.
Alex_Rm
