Just browsing
Intermittent Connection
Hope you are all safe and well,
I appear to be having intermittent issues with my WAN connection.
Here is a traceroute to Google DNS from a computer directly connected to the Super Hub via ethernet.
C:\Users\Shaun>tracert 8.8.8.8
Tracing route to dns.google [8.8.8.8]
over a maximum of 30 hops:
1 7 ms 8 ms 9 ms 10.5.160.1
2 7 ms 8 ms 6 ms wolv-core-2b-xe-813-0.network.virginmedia.net [80.3.146.114]
3 * * * Request timed out.
4 11 ms 15 ms 10 ms eislou2-ic-3-ae0-0.network.virginmedia.net [94.174.238.226]
5 11 ms 10 ms 12 ms 72.14.212.2
6 12 ms 21 ms 11 ms 74.125.253.31
7 12 ms 12 ms 13 ms 172.253.65.209
8 12 ms 13 ms 21 ms dns.google [8.8.8.8]
A continuous ping to 192.168.0.1 shows no drops, but when I set a continuous to 80.3.146.114 I'm getting intermittent drops, this is causing issues with online gaming. 10.5.160.1 is not my network and apart of Virgin Media's but is not responding to ICMP so I can't continuous ping this layer 3 interface.
Reply from 80.3.146.114: bytes=32 time=8ms TTL=63
Reply from 80.3.146.114: bytes=32 time=9ms TTL=63
Request timed out.
Request timed out.
Reply from 80.3.146.114: bytes=32 time=10ms TTL=63
Reply from 80.3.146.114: bytes=32 time=15ms TTL=63
Here's a dump of the Network Status from the Super Hub:
Downstream ChannelsLock Status Channel ID Frequency Modulation Rx Power SNR Pre RS Errors Post RS Errors
Locked4163000000 HzQAM256-3.9 dBmV37.5 dB214215
Locked1139000000 HzQAM256-1.3 dBmV38.5 dB116014
Locked2147000000 HzQAM256-1.9 dBmV38.3 dB5260
Locked3155000000 HzQAM256-3.2 dBmV38.0 dB19730
Locked5171000000 HzQAM256-3.0 dBmV37.5 dB2817447
Locked6179000000 HzQAM256-2.9 dBmV37.5 dB189327
Locked7187000000 HzQAM256-3.6 dBmV37.5 dB215513
Locked8195000000 HzQAM256-4.9 dBmV37.2 dB61910
Upstream ChannelsLock Status Channel ID Frequency Modulation Tx Power Mode Channel Bandwidth Symbol Rate
Locked346200000 HzATDMA43.3 dBmV64QAM640000030720 Kbits/sec
Locked160300000 HzATDMA44.5 dBmV64QAM640000030720 Kbits/sec
Locked253700000 HzATDMA43.5 dBmV64QAM640000030720 Kbits/sec
Locked439400000 HzATDMA42.0 dBmV64QAM640000030720 Kbits/sec
I've done the usual such as rebooting the hub but the issue is still present. Any ideas?
Cheers, Shaun
  • 24.48K
  • 1.4K
  • 3.11K
Re: Intermittent Connection
Your downstream levels are too low.
Is there an attenuator fitted to the back of the hub?
Just browsing
Hi Gary,
Thank you for the incredibly quick reply!
No attenuator, straight up coax from the back of the hub to where ever it goes back to. It is a Super Hub 2 so if I upgrade it does the Super Hub 3 come with one?
Cheers, Shaun
  • 24.48K
  • 1.4K
  • 3.11K
No it won’t.
You'll likely need an engineer visit to resolve
