  • 12
Message 1 of 9
Intermittent Connection with Low looking power levels
Hi All,
Wonder if anyone can help. The past few days I've started to get an intermittent connection, about twice a day the connection drops for a few minutes and then slowly comes back up to full speed. Not great when working from home like most people!!
Looking at the hub logs I can see what seem to be low power levels and a reasonable amount of Post RS Errors on the downstream. Does anyone know if these are in the expected range at all?
15390000000.238256 qam17
2547000000038256 qam18
3555000000-0.538256 qam19
4563000000038256 qam20
5571000000-138256 qam21
6579000000-0.538256 qam22
7587000000-0.938256 qam23
8595000000-1.438256 qam24
9603000000-1.238256 qam25
10611000000-1.538256 qam26
11619000000-1.538256 qam27
12627000000-1.238256 qam28
13635000000-1.738256 qam29
14643000000-1.738256 qam30
15651000000-2.538256 qam31
16659000000-238256 qam32
17667000000-238256 qam33
18675000000-2.238256 qam34
19683000000-2.738256 qam35
20691000000-3.237256 qam36
21699000000-437256 qam37
22707000000-437256 qam38
23715000000-4.437256 qam39
24723000000-437256 qam40
1Locked38.6796233
2Locked38.6808143
3Locked38.6669391
4Locked38.6553501
5Locked38.6460690
6Locked38.9475588
7Locked38.6730295
8Locked38.6657392
9Locked38.9716326
10Locked38.6856144
11Locked38.6817234
12Locked38.6790234
13Locked38.693287
14Locked38.686842
15Locked38.695317
16Locked38.62700
17Locked38.678812
18Locked38.691856
19Locked38.695438
20Locked37.310043
21Locked37.614416
22Locked37.68010
23Locked37.6169857
24Locked37.61530122
1326000394.371512016 qam5
2394013234.35512016 qam4
3462001084.375512016 qam3
4258008654.35512016 qam6
3ATDMA0000
4ATDMA0000
  • 15.72K
  • 1.64K
  • 2.68K
Message 2 of 9
Re: Intermittent Connection with Low looking power levels
All power levels are in spec.
Are ethernet cable connected devices also dropping at the same time as the wifi ones?
Re the RS errors - can you reboot the Hub and check that all values have reset to 0 - then monitor them every few hours for the next day or two and see if they reappear - they shouldnt.
Also post up the "Network Logs" data
Also, in the meantime, (if you haven’t already) set up a free “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” when you have the first 24h period.
  • 12
Message 3 of 9
Yes everything goes, wired and wireless.
Will reboot the router to get a clear picture but those post rs errors will have only built up in the last 36 hours as I rebooted it Monday night.
I've got a BQM running now so will post it's results once I have a decent sample.
Would the high errors indicate some noise on the line?
  • 15.72K
  • 1.64K
  • 2.68K
Message 4 of 9
"Would the high errors indicate some noise on the line?"
That would be the obvious explanation, and would need a tech visit to investigate. Lets see how the "Network logs" and BQM looks - as well as if the PostRS error counts continue to increase they shouldn't.
You could also, do a quick check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any splitters/attenuators/etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box.
  • 12
Message 5 of 9
So interestingly just had another drop for about a couple of minutes at roughly 11:53
The BQM shows the drop (below) however as I was working at the time I was able to get into the hub and grab the usual details and it had dropped to only 1 channel both up and down and my network access had dropped to not allowed.
<a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/3ab65cfbbc283844bef56d1fe4aa54f0183b0cd1-23-07-2020"><img alt="My Broadband Ping - Virgin Internet Test" src="https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/3ab65cfbbc283844bef56d1fe4aa54f0183b0cd1-23-07-2020.png" /></a>
See details below, this was taken during the outage. Makes me wonder if the Hub is on the way out.
Cable Modem Status
Item
Status
Comments
539000000
Locked
Ranged Upstream Channel (Hz)
32600000
Locked
Provisioning State
Offline
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
539000000
-0.5
38
256 qam
17
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.6
5
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
4.75
5120
64 qam
5
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
General Configuration
Network access
Not allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID
Max Traffic Rate
Max Traffic Burst
Min Traffic Rate
Primary Upstream Service Flow
SFID
Max Traffic Rate
Max Traffic Burst
Min Traffic Rate
Max Concatenated Burst
Scheduling Type
Time
Priority
Description
22/07/2020 13:40:3
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:08:55
critical
01/01/1970 00:08:14
critical
DHCP FAILED - Request sent, No response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:06:42
critical
01/01/1970 00:06:3
critical
DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:04:57
critical
01/01/1970 00:04:18
critical
01/01/1970 00:03:13
critical
01/01/1970 00:02:34
critical
16/07/2020 23:51:37
critical
16/07/2020 13:36:8
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/07/2020 13:36:4
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/07/2020 13:36:4
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/07/2020 13:36:4
critical
16/07/2020 13:36:3
Warning!
16/07/2020 13:35:54
Warning!
16/07/2020 13:35:50
critical
16/07/2020 13:35:49
Warning!
16/07/2020 13:35:49
critical
16/07/2020 13:35:49
Warning!
  • 15.72K
  • 1.64K
  • 2.68K
Message 6 of 9
You need VM input for this - call it in and also wait here for a VM person to pick it up - might be a day or two for that.
  • 12
Message 7 of 9
Cheers, appreciate the help.
Getting through on the phone isn't easy so fingers crossed one of the forum team can pickup on here.
  • 2.32K
  • 140
  • 178
Message 8 of 9
Hi arronrose871,
Thanks for your post.
I'm sorry that you're experiencing an intermittent connection both wired and wirelessly. I'd like to help you, but I haven't been able to locate your account to investigate.
I'll pop you a private message so I can have a closer look at things 🙂
Melissa
  • 2.32K
  • 140
  • 178
Message 9 of 9
Thank you for letting me know your details.
I've had a look at the account and there is currently an SNR (signal to noise ratio) issue in your area which is affecting your broadband.
Our team are currently working on getting this fixed, and the current estimated fix time is 28th July 09:00.
The reference number is F008243680, and whilst you can't track this yourself, you can always pop back here for an update.
Melissa
