allforme3
Message 1 of 8
Intermittent Connection, Lots of Pre errors and some Post RS errors - SA1
Hi All,
Since Friday, my connection has not been stable. When it restarts some of the power levels are 0 or close to, but as the time goes on the power levels drops, it reconnects and the cycle begins again.
Also having a lot of errors in the logs. After only 45 mins online.
1323000000-4.538256 qam24
2139000000-1.538256 qam1
3147000000-1.740256 qam2
4155000000-1.740256 qam3
5163000000-240256 qam4
6171000000-2.238256 qam5
7179000000-2.437256 qam6
8187000000-2.437256 qam7
9195000000-2.538256 qam8
10203000000-339256 qam9
11211000000-3.238256 qam10
12219000000-3.238256 qam11
13227000000-3.438256 qam12
14235000000-3.738256 qam13
15243000000-438256 qam14
16251000000-4.240256 qam15
17259000000-438256 qam16
18267000000-438256 qam17
19275000000-4.240256 qam18
20283000000-4.538256 qam19
21291000000-4.538256 qam20
22299000000-4.238256 qam21
23307000000-4.438256 qam22
24315000000-4.738256 qam23
1Locked38.911729
2Locked38.66790157988
3Locked40.3625831811
4Locked40.33171103
5Locked40.3809993
6Locked38.6302481
7Locked37.6383581
8Locked37.6340166
9Locked38.9557671
10Locked39.3278463
11Locked38.9245376
12Locked38.9187058
13Locked38.9225860
14Locked38.9167958
15Locked38.9107153
16Locked40.376856
17Locked38.956755
18Locked38.936859
19Locked40.330931
20Locked38.922243
21Locked38.919444
22Locked38.915732
23Locked38.914527
24Locked38.611732
allforme3
Message 2 of 8
Re: Intermittent Connection, Lots of Pre errors and some Post RS errors - SA1
Adding other information.
13260000050.8512064 qam5
23940000050.3512064 qam4
34620000050.3512064 qam3
42580000049.8512064 qam6
3ATDMA0000
4ATDMA0000
02/05/2021 10:29:28criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2021 10:26:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2021 10:15:40Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2021 10:13:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2021 10:13:40Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2021 10:10:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2021 10:09:25criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2021 10:05:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
lotharmat
  • 838
  • 56
  • 119
Well-informed
Message 3 of 8
Upstream power looks to be borderline high! That, along with the PostRS Errors means you may need an engineer visit to rectify!
When was the last time you rebooted the hub?
allforme3
Message 4 of 8
The router was rebooted, 45 minutes before I opened this thread
Upload currently looks like this:
13260000049.3512064 qam5
23940000049.3512064 qam4
34620000049.8512064 qam3
42580000049512064 qam6
lotharmat
  • 838
  • 56
  • 119
Well-informed
Message 5 of 8
In that case - with the PostRS errors climbing; I'd say that there is likely noise on the circuit!
Sasha_W
  • 924
  • 38
  • 70
Message 6 of 8
Hi @Alforme3,
Welcome to the forum page and thanks for posting this on here.
Sorry to hear you're having some intermittent connections but we can certainly look into this for you.
From taking a look at your account via your forum information, everything does look okay to me. There are no faults or outages but we can take a closer look if you are still experiencing drop outs.
Just some questions,
When you experience intermittent connection is it on all devices or just some?
How is your wired connection looking does this also have intermittent connections?
I can see that you have rebooted your hub recently but does this also include a pin hole reset?
Please do let me know.
Sasha - Forum Team
allforme3
Message 7 of 8
Hello,
Yesterday i did a pin-hole reset and it looks like it picked up some new downstream channels. The Pre and Post RS errors have dropped substantially. with a few post errors that have been there since yesterday. Pre RS errors do increase by around 1 per hour.
Upload stats are still around the same power levels:
16030003450.3512064 qam1
23940000048.8512064 qam4
34619998049.3512064 qam3
45370000050512064 qam2
Other than a T3 and a T4 timeout at 2 and 3am. There hasn't been an issue:
04/05/2021 02:47:33criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2021 01:33:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
I have 1 wired device and 1 wireless device, when the connect was lost, both lost internet connection until it reconnected or i manually restarted the router.
 Link to the BQM i setup: https://www.thinkbroadband.com/broadband/monitoring/quality/share/006432a03cd75ac7d170ac3d448c8d01b3...
Sasha_W
  • 924
  • 38
  • 70
Message 8 of 8
Hi @allforme3
I have decided to book you an engineer and will PM you the details.
If you wish to change or cancel this, you can via your online virgin media account at your orders section.
If you do also have any issues please feel free to message me again and I am more than happy to help you.
At the top right hand corner of your screen you will see a purple envelope, please click on that and it will take you to PM's.
Sasha - Forum Team
