iriches
  • 11
Intermittent Connection Loss - MK41
I've suffering intermittent connection losses on my VM broadband.
When the connection goes down, one of the lights on the front of the router (the vertical double-headed arrow) changes from blue to green.  Running the VM service status check reveals no problems in my area, and tells me to check the connections to the router and/or try rebooting it.
The connections are all fine.  Rebooting has no effect.
It normally fixes itself in between 1-3 hours. The green light will spontaneously turn blue again, and all will be well.  Until the next time...
As the online page seems to want a 24 hour period of no service, I can't work out how to book an engineer.
Screenshots from the router are shown below.
Any clues on how to get this fixed?
Thanks.
  • 23.98K
  • 2.54K
  • 4.36K
Re: Intermittent Connection Loss - MK41
Something not right there.
What Hub model is it exactly - printed on the base sticker?
CFan yoiu do a pinhole reset at per below and also try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. on known faults and tells you of more local issues down to postcode level. See if anything is reported.
_______________________________________________________________
Do a Hub “pinhole reset” - make sure the 2 passwords on the Hub sticker are still there and legible first ! Disconnect any ethernet cables from the Hub (leave the coax connected), and then with the Hub still "switched on" throughout, press pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 seconds, release the pin, leave for 5’ to stabilise - dont manually switch it off at any time. See if that sorts it
Martin_N
  • 5.59K
  • 234
  • 322
Hi iriches,
Thank you for your post. I'm very sorry to hear about the broadband issue you're having.
I have been able to locate your account and have taken a look on our side.
After running some check our system has advised that we have identified a short term network issue and we are working to resolve this very soon.
At this point in time we would advise monitoring the connection.
^Martin
