Mystrex1979
  • 19
Message 1 of 26
Intermittent Connection Issues
For a considerable amount of time, I have been having intermittent connection issues. Ordinarily I would notice a complete disconnect, just a slow-down in webpage processing times. I play a fair few online games, generally with no noticable issue. I have only noticed these intermittent connections recently due to playing World of Warcraft. **Note - These issues are *not* with WoW, but are most definitely due to a problem with my connection**
Everything that needs to be done has been done, I have rebooted and factory reset the Hub to no avail.
Please see logs below:-
Cable Modem Status
Item Status Comments
138750000
Locked
Ranged Upstream Channel (Hz)
39400000
Locked
Provisioning State
Online
1 138750000 2.5 40 256 qam 1
2 146750000 2.2 40 256 qam 2
3 154750000 1.7 40 256 qam 3
4 162750000 1.5 40 256 qam 4
5 170750000 1.4 40 256 qam 5
6 178750000 0.9 40 256 qam 6
7 186750000 1.2 40 256 qam 7
8 194750000 1 40 256 qam 8
9 202750000 0.7 40 256 qam 9
10 210750000 0.2 40 256 qam 10
11 218750000 -0.2 40 256 qam 11
12 226750000 -0.4 40 256 qam 12
13 234750000 -0.5 40 256 qam 13
14 242750000 -0.5 40 256 qam 14
15 250750000 -0.5 40 256 qam 15
16 258750000 -0.5 40 256 qam 16
17 266750000 -0.5 40 256 qam 17
18 274750000 -0.5 40 256 qam 18
19 282750000 -0.5 40 256 qam 19
20 290750000 -0.9 40 256 qam 20
21 298750000 -1.2 40 256 qam 21
22 306750000 -1.7 40 256 qam 22
23 314750000 -2.2 40 256 qam 23
24 322750000 -2.4 38 256 qam 24
1 Locked 40.3 3261230 1012646
2 Locked 40.3 1071558 105973
3 Locked 40.3 2150965 360590
4 Locked 40.3 3290989 1035526
5 Locked 40.9 498126 33329
6 Locked 40.3 2357489 445177
7 Locked 40.3 1344694 138633
8 Locked 40.3 766118 54816
9 Locked 40.9 443387 21975
10 Locked 40.3 148819 6002
11 Locked 40.3 162151 7861
12 Locked 40.3 840647 62550
13 Locked 40.3 890875 71857
14 Locked 40.3 185051 14652
15 Locked 40.9 155579 14049
16 Locked 40.3 356381 11478
17 Locked 40.3 1062182 89841
18 Locked 40.3 510929 20443
19 Locked 40.3 113128 4002
20 Locked 40.3 121152 2208
21 Locked 40.3 525126 12601
22 Locked 40.3 268090 5635
23 Locked 40.3 118826 1919
24 Locked 38.9 200044 3621
1 39400000 48 5120 64 qam 9
2 46200000 48.3 5120 64 qam 8
3 53699970 48.5 5120 64 qam 7
4 60300000 48.8 5120 64 qam 6
1 ATDMA 0 0 1 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 1 0
4 ATDMA 0 0 0 0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsl10016u-b.cm
SFID 18190
Max Traffic Rate 117000047
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 18189
Max Traffic Rate 10500047
Max Traffic Burst 16320
Min Traffic Rate 0
Max Concatenated Burst 16320
Scheduling Type BestEffort
12/11/2020 13:36:28 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 13:35:58 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 13:35:34 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 13:35:23 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 13:34:31 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 13:13:19 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 13:12:45 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 13:12:31 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 13:10:52 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 13:07:54 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 13:05:31 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 13:03:55 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 13:03:7 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 12:47:42 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 12:47:29 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 12:44:0 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 12:44:0 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 12:34:24 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 12:33:19 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 12:07:18 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mystrex1979
  • 19
Message 2 of 26
Re: Intermittent Connection Issues
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 26
The BQM is showing WAN side issues.
Your Pre & Post RS Error counts are very high.
In an ideal world they would be at zero and stay there. To zero them can you reboot the Hub using this method and then keep an eye on the counts.
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then check the counts again in an hour or so.
Mystrex1979
  • 19
Message 4 of 26
Thanks for your response. I have done as you asked and will keep an eye out.
Mystrex1979
  • 19
Message 5 of 26
This is still occuring, logs below:-
Cable Modem Status
138750000
Locked
39400000
Locked
Provisioning State
Online
1 138750000 2.2 38 256 qam 1
2 146750000 2 38 256 qam 2
3 154750000 1.5 37 256 qam 3
4 170750000 1.2 38 256 qam 5
5 178750000 0.9 37 256 qam 6
6 186750000 1.2 37 256 qam 7
7 194750000 1 40 256 qam 8
8 202750000 0.5 40 256 qam 9
9 210750000 0 40 256 qam 10
10 218750000 -0.2 40 256 qam 11
11 226750000 -0.4 40 256 qam 12
12 234750000 -0.4 40 256 qam 13
13 242750000 -0.2 40 256 qam 14
14 250750000 0 40 256 qam 15
15 258750000 -0.2 38 256 qam 16
16 266750000 -0.2 37 256 qam 17
17 274750000 -0.4 38 256 qam 18
18 282750000 -0.4 40 256 qam 19
19 290750000 -0.7 38 256 qam 20
20 298750000 -1.2 38 256 qam 21
21 306750000 -1.7 37 256 qam 22
22 314750000 -2 39 256 qam 23
23 322750000 -2.2 38 256 qam 24
1 Locked 38.9 449752 65530
2 Locked 38.9 89271 17972
3 Locked 37.6 73369 77087
4 Locked 38.2 95520 29178
5 Locked 37.3 206541 42968
6 Locked 37.9 46412 28274
7 Locked 40.9 12133 2088
8 Locked 40.3 6056 1292
9 Locked 40.3 1887 348
10 Locked 40.3 1841 434
11 Locked 40.3 8520 740
12 Locked 40.3 9297 1013
13 Locked 40.3 2226 1091
14 Locked 40.3 1067 820
15 Locked 38.9 25283 831
16 Locked 37.9 32150 9901
17 Locked 38.9 28717 1814
18 Locked 40.9 944 162
19 Locked 38.9 3895 123
20 Locked 38.9 19900 2520
21 Locked 37.9 17127 470
22 Locked 39.3 894 36
23 Locked 38.9 1118 100
1 39400000 48.3 5120 64 qam 9
2 46200000 48.8 5120 64 qam 8
3 53700268 49.5 5120 64 qam 7
4 60300292 49.8 5120 64 qam 6
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID 20848
Min Traffic Rate 0
SFID 20847
Min Traffic Rate 0
12/11/2020 19:07:15 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 19:07:4 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 19:06:55 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 19:05:43 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 17:40:49 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 17:40:36 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 17:39:25 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 16:09:24 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 16:09:18 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 14:27:35 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 13:39:0 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mystrex1979
  • 19
Message 6 of 26
I'm still having problems with this. New logs below:-
138750000
Locked
39400000
Locked
Provisioning State
Online
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID 20848
Min Traffic Rate 0
SFID 20847
Min Traffic Rate 0
12/11/2020 19:13:10 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 19:12:50 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 19:11:16 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 19:11:3 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 19:09:39 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mystrex1979
  • 19
Message 7 of 26
Mystrex1979
  • 19
Message 8 of 26
Re: Intermittent Connection Issues never went away.....
Hello again,
So my issue never resolved itself, I have switched the Superhub 3 into Modem Mode and bought a router in the hopes that this would stop the connection dropouts. It hasn't at all, things were going (relatively) swimmingly throughout yesterday, with 2 disconnects (one at midday, the other at 13:00). There was a disconnect at 02:00 this morning but I was not around to witness this. Forward to this afternoon - as you can see from the image below, things have gotten worse...
I have also copied my logs and will post them into a separate message. The Superhub was rebooted at around 16:30 (hence the massive red line in the image)
Mystrex1979
  • 19
Message 9 of 26
138750000
Locked
32600000
Locked
Provisioning State
Online
1 138750000 2 40 256 qam 1
2 146750000 1.2 40 256 qam 2
3 154750000 1 40 256 qam 3
4 162750000 1 40 256 qam 4
5 170750000 1 40 256 qam 5
6 178750000 0.4 40 256 qam 6
7 186750000 0.7 40 256 qam 7
8 194750000 0.7 40 256 qam 8
9 202750000 0.2 40 256 qam 9
10 210750000 -0.4 40 256 qam 10
11 218750000 -0.7 40 256 qam 11
12 226750000 -0.9 40 256 qam 12
13 234750000 -0.9 40 256 qam 13
14 242750000 -0.9 40 256 qam 14
15 250750000 -1 40 256 qam 15
16 258750000 -1.2 40 256 qam 16
17 266750000 -1 40 256 qam 17
18 274750000 -1 40 256 qam 18
19 282750000 -0.7 40 256 qam 19
20 290750000 -1 40 256 qam 20
21 298750000 -1.7 40 256 qam 21
22 306750000 -2.2 38 256 qam 22
23 314750000 -2.5 40 256 qam 23
24 322750000 -2.7 38 256 qam 24
1 Locked 40.3 8594 17434
2 Locked 40.9 19546 2075
3 Locked 40.9 11335 6487
4 Locked 40.3 8827 10001
5 Locked 40.9 1227 0
6 Locked 40.3 14 0
7 Locked 40.3 6 0
8 Locked 40.3 6 0
9 Locked 40.3 5 0
10 Locked 40.3 26 0
11 Locked 40.3 39 0
12 Locked 40.3 38 0
13 Locked 40.9 50 0
14 Locked 40.3 20 0
15 Locked 40.3 9 0
16 Locked 40.3 0 0
17 Locked 40.3 274 0
18 Locked 40.3 8 0
19 Locked 40.9 6 0
20 Locked 40.3 5 0
21 Locked 40.3 7 0
22 Locked 38.9 5 0
23 Locked 40.3 7 0
24 Locked 38.6 0 0
1 32600000 48 5120 64 qam 10
2 39400000 48.8 5120 64 qam 9
3 46200000 49.8 5120 64 qam 8
4 53700000 49.8 5120 64 qam 7
1 ATDMA 0 0 0 0
2 ATDMA 0 0 2 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 1 0
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID 25180
Min Traffic Rate 0
SFID 25179
Min Traffic Rate 0
15/11/2020 17:20:46 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 17:14:12 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 17:13:3 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 17:13:2 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 17:11:32 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 17:11:20 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 17:08:41 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 17:08:25 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 17:02:59 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 17:02:33 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 16:58:15 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 16:53:7 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 16:50:27 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 16:49:39 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 16:47:52 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 16:47:47 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 16:47:46 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 16:45:3 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 16:42:58 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 16:41:38 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mystrex1979
  • 19
Message 10 of 26
This all seems to coincide with my TomTom wanting to download an update (which, incidentally it has managed flawlessly on the in-laws Sky BB)
