Tom113
Intermittent Broadband regular drop outs
I've been experiencing some fairly regular drop outs since around the start of January, sometimes it's only a few seconds, but the sometimes I need to reboot my SH 3(which is running in modem mode). When this happens all devices wired and wireless are unable to connect to the internet, and when I try to hit the SH 3 in modem mode at 192.168.100.1, it doesn't work.
Here is a link to my bqm: https://www.thinkbroadband.com/broadband/monitoring/quality/share/d2dde432391b8a86f58dc4b09012c5136d...
Here is my network log which has some errors:
25/01/2021 15:59:28criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 15:51:38criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 15:49:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 05:04:35criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2021 19:14:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2021 18:45:58noticeNOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2021 17:02:39criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2021 06:13:55criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2021 04:01:45noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2021 04:01:45ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2021 08:47:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/01/2021 17:34:3noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/01/2021 17:34:3ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 18:55:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 20:42:44criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 05:34:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:55criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:47criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 05:29:49noticeSW download Successful - Via NMS
15/01/2021 05:28:10noticeSW Download INIT - Via NMS
My downstream:
14350000004.140256 qam36
22350000001.738256 qam13
3243000000238256 qam14
42510000002.738256 qam15
52590000002.738256 qam16
62670000003.238256 qam17
72750000002.938256 qam18
82830000002.738256 qam19
92910000003.438256 qam20
102990000003.538256 qam21
11307000000440256 qam22
123150000003.738256 qam23
133230000004.538256 qam24
143470000004.340256 qam25
153550000004.138256 qam26
163630000004.140256 qam27
17371000000440256 qam28
183790000004.440256 qam29
193870000004.340256 qam30
203950000004.540256 qam31
214030000003.738256 qam32
224110000004.438256 qam33
234190000004.540256 qam34
244270000004.940256 qam35
Rest of logs will be in second message
Tom113
Re: Intermittent Broadband regular drop outs
Here are the rest of my logs (hit character limit) Downstream bonded channels
1Locked40.3211956005
2Locked38.9360
3Locked38.91670
4Locked38.9270
5Locked38.930
6Locked38.9230
7Locked38.9190
8Locked38.940
9Locked38.9160
10Locked38.990
11Locked40.390
12Locked38.920
13Locked38.900
14Locked40.310
15Locked38.950
16Locked40.340
17Locked40.950
18Locked40.360
19Locked40.950
20Locked40.300
21Locked38.920
22Locked38.940
23Locked40.360
24Locked40.3260
And upstream:
14620000245.3512064 qam3
23259994445.3512064 qam5
33940001245.3512064 qam4
45369999845.3512064 qam2
3ATDMA0000
4ATDMA0000
Please let me know if there is anything I have missed.
Thank you in advance 🙂
