on 20-08-2023 15:45
We've been having broadband connection issues for the past couple of weeks.
Connection will be lost, sometimes for minutes, sometimes for several hours, and speed has generally been appalling (<1 Mbps) but will occasionally get back to 250Mbps+ for a few minutes before disconnecting again.
An Engineer visited last week and swapped out a component (it seemed 'old' but wasn't defective) but the problems have persisted.
(Followed the online guidance, off/on, reset, etc many times).
I am unable to book another appointment online because the diagnostic says 'nothing wrong, try off/on' etc.
Clearly the logs indicate there is a more serious problem (T3 and T4).
Logs below -
on 20-08-2023 15:46
Cable Modem StatusItemStatusCommentsAcquired Downstream Channel (Hz)
Ranged Upstream Channel (Hz)
Provisioning State
on 20-08-2023 15:47
1 | 387000000 | 5.5 | 40 | 256 qam | 32 |
2 | 203000000 | 5.4 | 38 | 256 qam | 9 |
3 | 211000000 | 5.3 | 38 | 256 qam | 10 |
4 | 219000000 | 5 | 40 | 256 qam | 11 |
5 | 227000000 | 4.8 | 38 | 256 qam | 12 |
6 | 235000000 | 4.5 | 38 | 256 qam | 13 |
7 | 243000000 | 4.1 | 38 | 256 qam | 14 |
8 | 251000000 | 4.1 | 38 | 256 qam | 15 |
9 | 259000000 | 4.4 | 38 | 256 qam | 16 |
10 | 267000000 | 4.5 | 38 | 256 qam | 17 |
11 | 275000000 | 4.8 | 38 | 256 qam | 18 |
12 | 283000000 | 5 | 38 | 256 qam | 19 |
13 | 291000000 | 4.9 | 38 | 256 qam | 20 |
14 | 299000000 | 5 | 38 | 256 qam | 21 |
15 | 307000000 | 5 | 38 | 256 qam | 22 |
16 | 315000000 | 4.9 | 38 | 256 qam | 23 |
17 | 323000000 | 5 | 38 | 256 qam | 24 |
18 | 331000000 | 5.3 | 38 | 256 qam | 25 |
19 | 339000000 | 5.8 | 38 | 256 qam | 26 |
20 | 347000000 | 5.6 | 38 | 256 qam | 27 |
21 | 355000000 | 5.8 | 38 | 256 qam | 28 |
22 | 363000000 | 6 | 38 | 256 qam | 29 |
23 | 371000000 | 6 | 38 | 256 qam | 30 |
24 | 379000000 | 5.9 | 38 | 256 qam | 31 |
1 | Locked | 40.3 | 309 | 449 |
2 | Locked | 38.9 | 3103 | 678 |
3 | Locked | 38.9 | 2877 | 659 |
4 | Locked | 40.3 | 2705 | 722 |
5 | Locked | 38.6 | 2517 | 613 |
6 | Locked | 38.6 | 2210 | 600 |
7 | Locked | 38.9 | 2237 | 549 |
8 | Locked | 38.9 | 1901 | 665 |
9 | Locked | 38.6 | 1706 | 507 |
10 | Locked | 38.9 | 1397 | 520 |
11 | Locked | 38.9 | 1169 | 530 |
12 | Locked | 38.9 | 1024 | 489 |
13 | Locked | 38.9 | 997 | 475 |
14 | Locked | 38.6 | 883 | 431 |
15 | Locked | 38.9 | 714 | 561 |
16 | Locked | 38.9 | 640 | 422 |
17 | Locked | 38.6 | 582 | 448 |
18 | Locked | 38.6 | 521 | 508 |
19 | Locked | 38.6 | 461 | 424 |
20 | Locked | 38.6 | 452 | 479 |
21 | Locked | 38.9 | 383 | 437 |
22 | Locked | 38.9 | 361 | 420 |
23 | Locked | 38.9 | 396 | 454 |
24 | Locked | 38.9 | 358 | 411 |
on 20-08-2023 15:47
1 | 30100000 | 47.5 | 5120 | 64 qam | 4 |
2 | 23600000 | 47.5 | 5120 | 64 qam | 5 |
3 | 36600000 | 47.5 | 5120 | 64 qam | 3 |
4 | 43100000 | 47.5 | 5120 | 64 qam | 2 |
5 | 49600000 | 47.5 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 1 | 5 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 1 | 5 |
4 | ATDMA | 0 | 0 | 1 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
on 20-08-2023 15:47
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | fg87dsfd;kfoA,.iyewrkldJK |
SFID | 834 |
Max Traffic Rate | 287500061 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 833 |
Max Traffic Rate | 27500061 |
Max Concatenated Burst | 42600 |
Scheduling Type | BestEffort |
on 20-08-2023 15:48
20/08/2023 14:30:45 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2023 10:10:48 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2023 10:08:38 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2023 10:08:38 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2023 10:08:18 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2023 10:08:18 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2023 09:52:0 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2023 00:22:35 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2023 00:22:35 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2023 00:22:15 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2023 00:22:15 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2023 00:21:55 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2023 00:21:55 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2023 00:21:35 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2023 00:21:35 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2023 00:21:15 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2023 00:21:15 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/08/2023 23:11:27 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/08/2023 23:09:37 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/08/2023 23:09:37 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 21-08-2023 12:17
Hi @Philosophico 👋.
Thanks for reaching out to us. Apologies for the issues you have been having with your broadband, we can certainly assist you, we would need to bring you in for a private message to discuss this and resolve.
Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
Thanks.
Sabrina
