  • 25
Message 1 of 38
Intermittent Broadband Fault, Hub 4
I'm here to seek any insights into why my broadband is dropping out quite frequently I've setup a Tb account to monitor the connection quality unsure how to embed it in my posts I can access the Hub and show you the levels the cable coax connection is quite old between the hub and cab 40 years and is not a clean run its been cut in approximately three places and re-joined so if someone can get to the bottom of the issues am running into it would be greatly appreciated - Tia
  • 11.77K
  • 917
  • 1.51K
Message 2 of 38
Re: Intermittent Broadband Fault, Hub 4
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Can you post a 'Live Link' to your BQM please.
Then
Can you please
Mike Robinson
  • 25
Message 3 of 38
https://www.thinkbroadband.com/broadband/monitoring/quality/share/d263682a7d37b4a41c1464cdc3e33bf11e...
3.0 Downstream channels
11390000007.90000236.609653QAM2561
21470000007.50000036.609653QAM2562
31550000007.40000237.355988QAM2563
41630000007.40000237.355988QAM2564
51710000007.19999737.355988QAM2565
61790000006.90000237.636276QAM2566
71870000006.90000237.636276QAM2567
81950000007.00000037.355988QAM2568
92030000006.90000237.355988QAM2569
102110000006.69999737.355988QAM25610
112190000006.50000037.636276QAM25611
122270000006.50000037.355988QAM25612
132350000006.59999837.355988QAM25613
142430000006.09999837.355988QAM25614
152510000006.19999737.355988QAM25615
162590000006.09999837.355988QAM25616
172670000006.40000237.636276QAM25617
182750000006.80000337.355988QAM25618
192830000006.69999737.355988QAM25619
202910000006.69999737.355988QAM25620
212990000006.09999836.609653QAM25621
223070000006.19999737.355988QAM25622
233150000006.50000037.355988QAM25623
243230000006.59999837.355988QAM25624
253630000006.30000337.355988QAM25625
263710000006.59999837.636276QAM25626
273790000006.50000037.636276QAM25627
283870000006.00000037.355988QAM25628
293950000006.69999737.355988QAM25629
304030000005.69999736.609653QAM25630
314110000005.69999736.609653QAM25631
1Locked000
2Locked54711379100
3Locked54699311900
4Locked54724814600
5Locked54606562900
6Locked54554886500
7Locked54632575500
8Locked45955500100
9Locked45898994800
10Locked45876111800
11Locked45906092200
12Locked45487281300
13Locked45480159900
14Locked45394456800
15Locked45493098900
16Locked45764775000
17Locked45834433300
18Locked45836293800
19Locked45910341300
20Locked46118913300
21Locked46103999600
22Locked46094400400
23Locked46048747000
24Locked56943258300
25Locked56935294500
26Locked55364673200
27Locked57058441500
28Locked57352970100
29Locked57335848200
30Locked58534952300
31Locked401774329200
159964K1880QAM4096759
159Locked 2.6262536420
3.0 Upstream channelsChannel Frequency (Hz) Power Symbol Rate Modulation Channel ID
16030000045.5205995120 K /sec64QAM1
23940000044.5205995120 K /sec64QAM4
34620000044.5205995120 K/sec64QAM3
45370000045.0205995120 K /sec64QAM2
3.0 Upstream channels Channel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
  • 25
Message 4 of 38
Hi, Mike
The Live graph http link is;
My BQM
I'm struggling to copy in the router tables it tells me to 'correct highlighted errors' I keep trying to break the words so it will allow me to post I'll keep trying,.
  • 25
Message 5 of 38
My BQM
  • 25
Message 6 of 38
Hi, Mike
Hi Mike, Engineer was out yesterday he remade a break in the wire and wrapped it in p t f e tape and electrical insulation tape under the c a t v inspection he also made another break in the wire and re-joined it the connection drops off at random the plc power and downstream d b mv have dropped from what they where the router is still falling over it say's connected 'no internet connection' on both ethernet and wi-fi and does not reconnect, (requires turning off and on) to get it to reconnect for a little while.. he also overtightened the forward path attenuator so I can't actually remove which is kind of annoying? and it was overtightened on the hub required a metal spanner to remove..
Channel Frequency (Hz) Power (d B mV) SNR (dB) Modulation Channel ID
21470000007.40000236.609653QAM2562
41630000007.30000337.355988QAM2564
51710000007.09999837.355988QAM2565
61790000006.80000337.355988QAM2566
71870000006.80000337.355988QAM2567
92030000006.80000336.844463QAM2569
112190000006.40000237.355988QAM25611
122270000006.40000237.355988QAM25612
152510000006.19999736.609653QAM25615
162590000006.00000037.355988QAM25616
172670000006.30000337.355988QAM25617
182750000006.69999737.355988QAM25618
192830000006.59999837.355988QAM25619
202910000006.59999836.609653QAM25620
223070000006.19999736.609653QAM25622
233150000006.40000237.355988QAM25623
243230000006.59999836.609653QAM25624
263710000006.50000037.636276QAM25626
273790000006.50000037.355988QAM25627
293950000006.59999837.355988QAM25629
304030000005.59999836.609653QAM25630
Channel Lock Status Rx MER (dB) Pre RS Errors Post RS Errors
1Locked000
2Locked54722277600
3Locked54710056900
4Locked54734929600
5Locked54616815400
6Locked54565446000
7Locked54643595500
8Locked45959628600
9Locked45904189000
10Locked45880748700
11Locked45912523200
12Locked45492023800
13Locked45485283400
14Locked45398585300
15Locked45499392400
16Locked45769909900
17Locked45839345300
18Locked45841662000
19Locked45916602800
20Locked46124576800
21Locked46110139600
22Locked46100831400
23Locked46054564000
24Locked56948461300
25Locked56940597400
26Locked55369139000
27Locked57063935500
28Locked57360168600
29Locked57342909200
30Locked58542457800
31Locked412816585500
3.1 Downstream channels Channel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
3.1 Downstream channels Channel ID Lock Status Rx MER Data (dB) PLC Power (d B m V) Corrected s (Active Profile) Un correctable s (Active Profile)
159Locked 2.6264185780
  • 25
Message 7 of 38
Hi, Mike Upstream
I'm having difficulty adding the BQM link
keeps saying http link removed even though I selected the chain link (insert/edit link) to the left of the insert photo option.
Channel Frequency (Hz) Power (dB mV) Symbol Rate (k s p s) Modulation Channel ID
16030000045.5205995120 K S y m/sec64QAM1
23940000044.5205995120 K S y m/sec64QAM4
34620000044.5205995120 K S y m/sec64QAM3
45370000045.0205995120 K S y m/sec64QAM2
  • 25
Message 8 of 38
My BQM
My BQM
  • 25
Message 9 of 38
BQM
  • 24.66K
  • 1.42K
  • 3.14K
Message 10 of 38
Re: Hi, Mike Upstream
What’s dropping - wired or wireless connections?
