protaa
Intermitten Connection /Packet loss. FOR AROUND A WEEK
So recently, my network, for the past 5 days, randomly starts to stop working properly and I get constantly disconnected, I am plugged in via ethernet. When I check the speed, on an okay day I still get 100 but I get constant packet loss and sometimes it fails to work altogether. I'm using the Hub 3. On the 100 MB package and this is starting to get VERY frustrating. i will post the stats etc in a bit. pls help. Many Thanks
(P.S. I figured out it was packet loss whilst gaming and doing a bunch of 'packet loss' tests) how to fix?
protaa
Re: Intermitten Connection /Packet loss. FOR AROUND A WEEK
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1138750000337256 qam1
21467500003.537256 qam2
31547500003.537256 qam3
41627500003.537256 qam4
51707500002.737256 qam5
6178750000337256 qam6
71867500003.237256 qam7
81947500003.238256 qam8
92027500002.737256 qam9
102107500001.537256 qam10
112187500001.236256 qam11
122267500000.737256 qam12
132347500001.737256 qam13
142427500001.237256 qam14
15250750000137256 qam15
162587500000.537256 qam16
172667500000.937256 qam17
182747500000.237256 qam18
192827500001.537256 qam19
202907500002.938256 qam20
212987500003.538256 qam21
223067500003.738256 qam22
233147500003.438256 qam23
243227500003.538256 qam24
1Locked37.320
2Locked37.300
3Locked37.670
4Locked37.650
5Locked37.600
6Locked37.650
7Locked37.340
8Locked38.650
9Locked37.600
10Locked37.360
11Locked36.620
12Locked37.600
13Locked37.650
14Locked37.6120
15Locked37.6130
16Locked37.320
17Locked37.350
18Locked37.360
19Locked37.360
20Locked38.660
21Locked38.690
22Locked38.660
23Locked38.900
24Locked38.6210
protaa
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
12580013644.8512016 qam12
24620000044.8512064 qam8
33940000042.8512032 qam9
43260000044.5512064 qam10
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0070
2ATDMA0080
3ATDMA0070
4ATDMA00110
protaa
Network LogTime Priority Description
20/01/2021 23:52:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 23:51:17noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 23:27:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 23:25:26noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:07:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:06:34criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:05:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:04:30criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:03:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:45criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 23:08:21noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 23:06:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 22:46:27Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 22:14:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 22:03:24noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 21:47:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 21:30:12noticeSW download Successful - Via Config file
20/01/2021 21:28:3noticeSW Download INIT - Via Config file
20/01/2021 20:45:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
