  • 8
Intermittant connection
Hi I’ve been having intermittent connection for the last 4 days we are currently isolating as my daughter has COVID so we are relying heavily on the internet at the moment and I’d just like to know what’s going on as I can never get an answer from your telephone service thanks in advance
mathew
  • 12.22K
  • 946
  • 1.57K
Re: Intermittant connection
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Mike Robinson
  • 1.9K
  • 97
  • 177
Hi Gurunicknak, thanks for posting.
I am sorry to hear you're having issues with your broadband connection and sorry to hear you're having difficulties getting updates.  Have you seen the advice given by @MikeRobbo ?  There is some very good tips.  If you do still need help, we're here for you.
Lee_R
