  • 5
Intermittant WiFi
Hi, Wi-Fi intermittently drops out during the day but more frequently at night when my son is on his PS4, Called help line many times now but they saying hard wire PS4! . His PS4 is upstairs and router is down stairs. I tried all tests and scanned rooms with app which says all OK, Also tried a TP-LINK booster and still the same! Not sure what to do now? this is so frustrating can anyone suggest something - would a second router in his bedroom work so he could hard wire?
Tags (1)
  • 20.96K
  • 1.14K
  • 2.7K
Re: Intermittant WiFi
Wifi speeds and connectivity aren't guaratneed.
You can run some wired Access Points to improve the wifi or look into a Mesh System
  • 5
Thanks, I am not an expert on this so please bear with me, when you say an access point would a Power lIne adapter work better than my booster? not to sure of access pointdetails?
  • 20.96K
  • 1.14K
  • 2.7K
No powerlines are also prone to slow speeds
  • 5
Thank you so much for the advice , Can you recommend a good access point? also would I connect the access point to the router and then all devices  to the Access Point or just the PS4?
  • 20.96K
  • 1.14K
  • 2.7K
An access point requires a wired connection back to the router.
It depends if you want to run a cable to where the AP will be.
If not, then a Mesh Systen would be better suited.
