on 15-07-2021 16:39
Been in contact with @virginmedia the past 2 weeks about and today about internet interference in the house to be told to wait after 24 hours after they booster the line into the house. Photo 1 is back in March and photo 2 is today.
on 15-07-2021 16:49
You were told by customer services they were "boosting the line into the house"? All they can do as far as I'm aware is remote kick up the Arris for the hub*, which prompts the hub to renegotiate its connection. As a quick fix that often works, but unless any underlying hardware issue is fixed then it is a waste of time.
If you've tried the usual of restarts, resets, checking cable connections, and the problem has been going on for a while and still continues, then connect to the hub by clicking on this link http://192.168.0.1/ That should pull up the log in page for the hub. But don't log in, just click on the link "Check router status" That'll bring up a window with five tabs. Open the Downstream tab. Select all the text (Ctrl-A if using a keyboard), copy it (Ctrl-C), then paste it (Ctrl-V) into a reply here as TEXT not screenshots. Post that, do the same for the Upstream and Network log. You'll get an error message when you post the Network log, just click on "post" a second time. Then we can check for any obvious problems with power, noise or error counts.
* The hub is made by a company called Arris, I wasn't being uncouth, oh no sir, I'm not like that.
15-07-2021 17:01 - edited 15-07-2021 17:03
It appears from the screen images that those speed tests were done over a WiFi connection. If so the speed is not guaranteed and will always vary according to a number of local factors. One of them could indeed be interference from a neighbour's WiFi. Have you tried changing channels?
on 15-07-2021 17:22
1 | 331000000 | 2.5 | 38 | 256 qam | 25 |
2 | 203000000 | 2 | 37 | 256 qam | 9 |
3 | 211000000 | 2 | 37 | 256 qam | 10 |
4 | 219000000 | 2 | 37 | 256 qam | 11 |
5 | 227000000 | 1.5 | 37 | 256 qam | 12 |
6 | 235000000 | 1.5 | 37 | 256 qam | 13 |
7 | 243000000 | 0.7 | 37 | 256 qam | 14 |
8 | 251000000 | 1.7 | 37 | 256 qam | 15 |
9 | 259000000 | 0.7 | 37 | 256 qam | 16 |
10 | 267000000 | 1.7 | 37 | 256 qam | 17 |
11 | 275000000 | 0.4 | 37 | 256 qam | 18 |
12 | 283000000 | 2 | 38 | 256 qam | 19 |
13 | 291000000 | 0.7 | 38 | 256 qam | 20 |
14 | 299000000 | 2.4 | 38 | 256 qam | 21 |
15 | 307000000 | 0.5 | 37 | 256 qam | 22 |
16 | 315000000 | 2.2 | 38 | 256 qam | 23 |
17 | 323000000 | 1 | 38 | 256 qam | 24 |
18 | 339000000 | 1.4 | 38 | 256 qam | 26 |
19 | 347000000 | 2.2 | 38 | 256 qam | 27 |
20 | 355000000 | 1.5 | 38 | 256 qam | 28 |
21 | 363000000 | 2 | 38 | 256 qam | 29 |
22 | 371000000 | 1.5 | 38 | 256 qam | 30 |
23 | 379000000 | 1.5 | 38 | 256 qam | 31 |
24 | 387000000 | 1.4 | 38 | 256 qam | 32 |
1 | Locked | 38.6 | 0 | 0 |
2 | Locked | 37.6 | 6 | 0 |
3 | Locked | 37.6 | 7 | 0 |
4 | Locked | 37.6 | 5 | 0 |
5 | Locked | 37.6 | 1 | 0 |
6 | Locked | 37.3 | 6 | 0 |
7 | Locked | 37.6 | 1 | 0 |
8 | Locked | 37.3 | 0 | 0 |
9 | Locked | 37.3 | 0 | 0 |
10 | Locked | 37.6 | 1 | 0 |
11 | Locked | 37.6 | 1 | 0 |
12 | Locked | 38.6 | 0 | 0 |
13 | Locked | 38.6 | 1 | 0 |
14 | Locked | 38.6 | 0 | 0 |
15 | Locked | 37.6 | 1 | 0 |
16 | Locked | 38.6 | 0 | 0 |
17 | Locked | 38.6 | 0 | 0 |
18 | Locked | 38.6 | 0 | 0 |
19 | Locked | 38.6 | 5 | 0 |
20 | Locked | 38.9 | 0 | 0 |
21 | Locked | 38.6 | 3 | 0 |
22 | Locked | 38.6 | 6 | 0 |
23 | Locked | 38.6 | 4 | 0 |
24 | Locked | 38.6 | 3 | 0 |
on 15-07-2021 17:24
virgin confirmed it wasin my house
15-07-2021 17:29 - edited 15-07-2021 17:30
According to the figures you have just posted your broadband connection is working well.
You may wish to follow the advice links on improving WiFi in your house.
https://community.virginmedia.com/t5/Helping-Hands/bg-p/Helping_Hands/label-name/broadband
on 15-07-2021 17:40
Thanks for all the information, unfortunately we are completely unable to move our router , hasn’t moved since it was installed. We are probably gonna look at getting it moved
to
on 15-07-2021 19:01
@Andrewcowan wrote:Thanks for all the information, unfortunately we are completely unable to move our router , hasn’t moved since it was installed. We are probably gonna look at getting it moved
The thing with this method is that Virgin will have to lengthen the specialised coax & possibly change the signal levels to move it. A callout to move kit is not classed as a fault callout so will put you back £99 for something that may not solve the issue. Look at boosters or a mesh system, or even using a third party router that will work far better than the basic VM kit.
on 15-07-2021 19:53
on 17-07-2021 17:30
Hey @Andrewcowan,
Welcome to the community and thanks for getting in touch with us here.
We can arrange for your hub to be moved but as the members have said that it there will be a call out charge of £99 for the team to do this.
Would you like me to arrange this for you?
Regards,
Steven_L
