  • 3.84K
  • 154
  • 220
Message 21 of 28
Re: Important: Serious issue accessing Lloyds Bank, Playstation and Vodafone.
All services do usually have a way you can raise issues and queries with them if you scroll to the bottom of the website there may be a Contact Us section?
Thanks, Emily.
  • 8
Message 22 of 28
Not from what I can see on playstation network theres no contact us.
  • 12.16K
  • 944
  • 1.56K
Message 23 of 28
Here you go ...
https://www.playstation.com/en-gb/footer/about-us/
Mike Robinson
  • 5.21K
  • 581
  • 1.84K
Message 24 of 28
These blocks are usually in response to malicious activity originating from your public IP Address. Pursuing the cause with those website operators that are contactable should be a priority; a  change of IP Address may give some period of relief but unless the source of the malicious activity is identified it is likely to also be blocked.
Have I helped? Click Mark as Helpful Answer or use Kudos to say thanks
  • 8
Message 25 of 28
Thanks Mike but the link you gave I have already tried, it asks what your problem is goes through a few solutions but if they don't work just says contact your internet provider which I already did.  There is no email or phone number to contact for further support should your Internet provider not be able to solve it.
  • 5.48K
  • 616
  • 1.83K
Message 26 of 28
@Tah1780 From Google:
PS4 Tech Support How to contact PlayStation Customer Service Support
UK PlayStation Support
  • Telephone: 0203 538 2665
Opening times: Monday-Saturday 10.30am- 7.30pm BST
The UK also has excellent support on Twitter, with a team who responds quickly to your questions. Just tweet @AskPS_UK between 9.00-23.00 Mon- Sun
Or, you can email the team at: help@ukplaystation.com
Based on past experiences like this reported on the forum, Sony are usually not very helpful.
As others have stated this looks like an IP address block and PSN and Banks don't block IPs for fun they usually have a very good reason.
Have recently found this site which might be able to shed some light on the reputation of your current IP:
https://www.ipqualityscore.com/free-ip-lookup-proxy-vpn-test
You can also check if your IP address is banned by Akamai who provide online security for most banks and PSN (although this link seems to return less reliable results than it used to in the past):
https://www.akamai.com/us/en/clientrep-lookup/
______________________
Scott
My setup: V6 TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
  • 8
Message 27 of 28
Thanks Scot, I had already done those tests from links on a previous post with the same problem, they both said my IP was ok.  However today I can connect to both Lloyds and PlayStation network, I don't know what has changed and would of been helpful to of known what the problem was but they are now working.
Thankyou everyone for trying to help me.
  • 6K
  • 1.13K
  • 1.59K
Message 28 of 28
Hello
Educated response would  be that the sites in question have removed the block on your external (WAN) IP address, I am glad that the issue has now been resolved.
Regards Mike
